What do you think?
It looks like a Dayton interconnect from parts express.
Dayton 12ft Sub cable
You can buy them direct from PE for $11.70.
Cheers,
Thanx Russ. Do you think that they are acurate is there some thing I should move up to for better sound for the dollar.Wish I was a polkologist then I could call my self Dr.warviper.
I think they are a good entry-level cable to start with. The cable debate can be a mess, yes there are probably better cables out there, but there are also some that simply just cost more - for little to no performance gain.
If you are looking for a basic, shielded, well built cable, with decent connectors, go for it. I'd be willing to bet they will hold their own in the 'accuracy' dept with pretty much anything up to 3-4 times the price.
Cheers,
