help setting up receiver with this speaker setup
eyedev
eyedev Posts: 18
Can anyone direct me in setting up the large/small setting as well as bass cross over frequency for this setup?
front: 255c-rt (http://www.polkaudio.com/products/255crt#specs)
fronts: 90-rt (http://www.polkaudio.com/products/90rt#specs)
surrounds: 80fx-rt (http://www.polkaudio.com/products/80fxrt#specs)
sub: inifinity BU2 (100W, freq response: 30 Hz - 15 kHz, continuously crossover variable from 50 Hz - 200 Hz)
Thanks!
Post edited by eyedev on
  • classic carl
    classic carl Posts: 662
    edited January 2014
    What sounds best? Large or small? Let you ears decide. Set your sub crossover at the bottom of the frequency of your mains. If they go to 43 Hz, set your sub at or slightly above 50Hz. A little overlap won't hurt.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
