Polk Tsi 300
dcfaulcon
dcfaulcon Posts: 2
I have some Polk TSI 300 and I am purchasing a Yaqin MC10l. The problem is that the Yaqin has banana plug connectors. I bought some pre made 12 gauge connectors from a site and they are too big to go into the Polk. Any advice on the proper gauge and connectors I should for these two would be greatly appreciated.
    F1nut Posts: 52,370
    edited December 2013
    Both the Yaqin and the Polks have what are known as 5 way binding posts. You can use banana plugs, spades or bare wire, so I'm not sure what your issue is.
    Betcha his issue is those darn plastic caps Polk puts over the binding post nuts. If your using banana connectors you need to pop off the plastic cap....not the nut, the plastic over the nut. Otherwise spades or bare wire will work fine with those plastic caps in place.
