100uf Caps
daboyz
Looking to upgrade my x'overs so I need (4) 100uf caps to start. If you've got 'em or have seen a good deal then I'm your Huckleberry. I know it's probably a long shot that anyone has them.
Post edited by daboyz on
I didn't look, but I'm pretty sure Solen and Dayton do as well.Political Correctness'.........defined
President of Club Polk -
i am rebuilding a pair of Infinity RSb and am using these 100 uF Clarity caps from Madisound, at the best price I could find for them. They are quite large.
http://www.madisoundspeakerstore.com/sa-cap-630vdc/claritycap-100mfd-sa-range-polypropylene-cap/
here's a pic of the parts with a can of tomatoes to help judge scale of the Clarity next to it, if you need to know.Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
That is one BIG A$$ cap!JC approves....he told me so. (F-1 nut)
yes it is, and with the layout of the cab, and the weight of both that cap and the B.A. inductor next to it, I am going to mount the board on the floor of the speaker instead of with the binding posts. Beside the weight issuse, it would be difficult to lay out the board where that cap is not in the way of the woofer basket.Polk Lsi9
Keces DA-131 mk.II
I've been looking at the Clarity. Does anyone have experience with the Audyn?
http://www.parts-express.com/audyn-cap-q4-100uf-400v-mkp-metalized-polypropylene-foil-crossover-capacitor--027-125 -
If it's for low pass then solen woild be fine--and fairly cheap IIRCJC approves....he told me so. (F-1 nut)
Ive used the clairty sa's and the esa's and love thier sound. Size is a factor though. That looks like a 600 volt ck out the 250 volt one it is a bit smaller.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Size isn't really a huge issue. I have a lot of room.
IMO, the CC ESA would be the best in that value."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Yes, the ESA's are very good.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I have some 100uf Sonicaps....CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
really? last time I bought from them 2 or 3 months ago, I was told they would not make them that large.I have some 100uf Sonicaps....Polk Lsi9
Keces DA-131 mk.II
