Parasound or Adcom
JDOGG
JDOGG Posts: 433
edited January 2004 in Electronics
Which would be a better performer for my Klipsches, an Adcom or a Parasound? I don't need much wattage, because f the sensitivity of my speakers(97db). I was thinking an HCA 750 from Para. or an Adcom GFA 5300. Both of these look great, but I don't know if there is a difference in performance. Any input appreciateed.
http://www.adcom.com/amplifiers/gfa5300.htm
http://www.parasound.com/products/amplifiers/hca750a.html
Panasonic VIERA 46" 1080p plasma
Onkyo TX-SR805
Klipsch RF-7(bi-amped)
Klipsch RF-25
Xbox 360 with HD DVD
Playstation 3
Cobalt Cable
Post edited by JDOGG on
    VR3 Posts: 29,428
    edited January 2004
    Adcom GFA-535, Adcom GFA-535 II
    Have a great day,
    Sid
    PS: Eff the new ones, for the price they go for you can buy 2 of the old ones...
    PSS: I own 3 of the Adcom GFA-535, one of the original, 2 of the II versions. All 3 are great amps! You can't go wrong. They usually go for about 170 shipped.
  • JDOGG
    JDOGG Posts: 433
    edited January 2004
    Do you know of a website to get the old amps. I need new, nothing on Ebay or Audiogon.The dealer locator on Adcoms website showed nothing for Minnesota, unless there's something wrong with my internet. Oh, you have alot of great amps.:D
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
    VR3 Posts: 29,428
    edited January 2004
    Thank ya.
    EBay.
    If you need new because of warranty. The chances of you using an Adcom warranty is about as good of a chance as you meeting Osama.
    All these amps in my rack are 10 or so years old. I doubt any of them have had a problem. However, one does have a channel out which I use for my center amp but it runs fine other than that.
    You won't find many sites that still carry the 2 models I listed above, but I wouldnt leave EBay out of the list of things. Either way I would go with Adcom. lol
  • JDOGG
    JDOGG Posts: 433
    edited January 2004
    Nothing against the older amps, but I think I would like to stick with the newer amps. Thanks for the help
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
    F1nut Posts: 51,774
    edited January 2004
    I vote Parasound
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2004
    Since you have specifically mentioned those two brands.... Parasound, hands down IMO.
    Parasound was running specials on the HCA1500A, $699 brand new, 10 year warranty, 205x2@8....on the homepage....you may want to give them a call.
    www.parasound.com
  • tonyv1
    tonyv1 Posts: 365
    edited January 2004
    Another vote for Parasound. Take a look at their Halo line.
    VR3 Posts: 29,428
    edited January 2004
    I vote NAD, eff both of them :p
  • gmorris
    gmorris Posts: 1,179
    edited January 2004
    we had a good thread about Parasound going a couple days ago. here is the link:
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=15452
    Bob Mayo, on the keyboards. Bob Mayo.
  • tonyv1
    tonyv1 Posts: 365
    edited January 2004
    How about a tube amp? It'll drive the Klipsches and serve as a heater for those Minnesota winters.
  • organ
    organ Posts: 4,969
    edited January 2004
    That's a great suggestion, Tony, but I'm not sure if JDOGG is still thinking about getting tube amps. He was looking into them a few days ago.
    JDOGG,
    So you're set on SS now? For the price of the two Parasound amps you're planning to get, you can buy an Antique Sound Lab AQ1003DT integrated amp. Check it out at www.divertech.com I'll be getting one within 2-3 months. It has a built in bias meter so it's pretty much a "set it and forget it" kinda thing. Just tube replacement every year or two depending how often you use it.
    What kind of music do you listen to? Who knows, tubes may be right for you.
    Maurice
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited January 2004
    Between your two choices, Parasound without a doubt. Adcoms can tend to sound 'grainy', especially in the upper octaves. I'm afraid the Klipsch would only make it more apparent.
    If you are dead set on Parasound, I'd look at an HCA750, or 800 used. Even at 75wpc or so, it will be more power than you will ever use with very efficient speakers.
    A tube preamp will be a nice touch of air and openess on top of it all, and should make for a winning combo (imo).
    Cheers,
    Russ
  • JDOGG
    JDOGG Posts: 433
    edited January 2004
    I listen to my system alot, at least a couplr hours every day. I listen to rock music. Mudvayne, Slipknot, Metallica to name a few.I just might be the only one who listens to these on this forum.
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
  • organ
    organ Posts: 4,969
    edited January 2004
    Nope, you're not the only one. I listen to a lot of extreme metal from Europe especially black metal. I also listen to classical and opera. I'm not farmiliar with your bands but tubes do make those complex passages sound better. Every instrument can be heard clearly. It's up to you. SS or tubes, you're going to have a killer system. Keep us posted.
    Maurice
  • JDOGG
    JDOGG Posts: 433
    edited January 2004
    As I said in my tube amp post, I need to build up my funds. I just got the new speakers and this computer I'm typing on a couple months ago.Back to shoveling and mowing lawns(in the summer). The reciever was a gift. Can't wait though.
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
  • organ
    organ Posts: 4,969
    edited January 2004
    That's cool. Take your time and do a lot of research before spending a lot of money. If I get my ASL before your upgrade, I'll let you know how it performs on the Klipsch. Our speakers are very similar except the driver/cab/horn size and 1db difference between the 25 and 35.
    Maurice
  • JDOGG
    JDOGG Posts: 433
    edited January 2004
    Two mono blocks might be cool for you organ.
    http://www.divertech.com/aslwaveav20dt.htm
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
  • goingganzo
    goingganzo Posts: 2,793
    edited January 2004
    i would say adcom b&k rotel or anthem or sunfire
  • dorokusai
    edited January 2004
    I think it is nice to see someone ask for a comparison between two specific amplifiers, and get 100 alternate choices.
    I think that someone that chose, of all amplifiers, Adcom and Parasound...that he at least gave a little thought to the idea. Can we give him some credit, and comment on his two(2) choices? He didn't choose Radio Shack, Sears or even the high speed Wal-Mart brand.
    Buy whatever you want, its your money. I am sure you will make the right decision.
  • JDOGG
    JDOGG Posts: 433
    edited January 2004
    Since I will eventually be adding another amp, would it be better to buy monoblocks? Like Outlaw's new Model 200 M-block amp.
    http://www.outlawaudio.com//products/200.html
    So many amps to choose. Why is it so hard?
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
  • organ
    organ Posts: 4,969
    edited January 2004
    JDOGG,
    I did think about those mono blocks at one time. The earlier models (Wave 8 and 10) received some nice reviews. But I think I'm getting the AQ1003DT for the EL-34 power tubes. I have an EL-34 tube fetish. Those are the power tubes I used on the Dyna amp and I love their sound. Most audiophiles like them the most too because they have "character" and also have the most "romantic" sound. I couldn't agree more.
    A lot of people like mono blocks because you get a seperate power supply for each channel and there's no chance of "crosstalk" between channels. It could still happen in the pre or source though.
    Just remember that your speakers won'tt need too much power because of their high sensitivity. Also, some people say that very high powered SS amps are not a good match with high sensitivity speakers because the amp will hardly be putting out any power and amps have "crosstalk" and more distortion when driving horns with very little power. Not sure if this is true though. My NAD is 120w/ch and it sounds fine with the Klipsch.
    Maurice
  • JDOGG
    JDOGG Posts: 433
    edited January 2004
    I hope to have my center and two mains amped. I have two shelf spaces left on my A/V rack each with a foot if not more apart. Would stack ing these make them run hot? The main amps stcked and the center channel on its own shelf, or just stack them all.My uncle told me about how you should have more power going to your speakers than what is listed. Like if they are 125 wts RMS, then have 150,200. Is this true. Thanks everyone for responding and being patient.:)
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
  • JDOGG
    JDOGG Posts: 433
    edited January 2004
    Maybe just one of these.
    http://www.soundcity.com/product.php?product_id=14335&id1=HOME%20AUDIO
    hahahaha yea right, never would buy it. Even if it was free.
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
  • organ
    organ Posts: 4,969
    edited January 2004
    But don't you think they'd look cute with a pair of B*se cubes and that puppy woof box?;)
    I wouldn't stack amps due to heat buildup. I know some amps run cool but my friend's Yammi receiver kept going into protect mode everytime it gets too hot because he didn't provide enough clearence. I see some people stacking amps and they don't have any problem.
    Your uncle is right but only for power hungry speakers like the LSi and not high efficiency speakers.
    Do you know about the Klipschorn from the Heritage line? It's their most sensitive speaker and believe it or not, their owners power them with 2w/ch SET tube amps! You won't be using all that extra power. Your speakers will play loud with little juice.
    Maurice
    VR3 Posts: 29,428
    edited January 2004
    Stacking amps...hmm
    It runs hot, but honestly...Adcoms run hot anyways, so let them be hot...lol
    You could get Klipsch to play 110db with tin foil and a tazer...
    How about a Audiosource? Can be found on EBay and Partsexpress.com
    Due to the brightness of Adcoms, Ima have to vote parasound or nad...possibly AMC
  • JDOGG
    JDOGG Posts: 433
    edited January 2004
    Organ,
    do you think 125wts from an HCA 1000A is too much? Whats the difference between the 125 and the 125 wts from the Halo A23? Is it worth the extra $200? The Halo looks 100 times better.
    http://www.audioadvisor.com/store/productdetail.asp?sku=PARHA23&product_name=Halo%20A23%20Balanced%20Amplifier
    http://www.audioadvisor.com/store/productdetail.asp?sku=PARHCA1000A
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
  • organ
    organ Posts: 4,969
    edited January 2004
    That's plenty. At one time when my parents went out I got the RF-35 to play at concert level using a 35w/ch tube amp. I have no experience with Parasound so I can't say if the Halo is worth the extra $200. Best thing to do is to find out which model is brighter sounding and avoid that. With your speaers you'd want a warmer sounding amp. With most SS amp, you'll have no choice of getting an amp that's under 100w/ch. My SS amp is 120w/ch and it sounds great with the RF-35.
    Have you looked at NAD? I'm using a C270 to power mine and it sounds super. I also find that switching pre amps make a big difference. The NAD pre sounds excellent but I find the Rotel pre too harsh and bright at high volume. It sounds great at low and mid volume though. The C270 has been replaced by another 2ch amp. I think it's a C272. You should be able to find one for under $500. Check out www.nadelectronics.com Read about the features especially the "Impedance Sensing Circuitry". I find that one very interesting.
    Maurice
  • JDOGG
    JDOGG Posts: 433
    edited January 2004
    I'm gonna try and get to an authorized dealer today or tomorrow. Thanks for all the help.:)
    Onkyo TX-SR805
    Klipsch RF-25
    Playstation 3
    Cobalt Cable
    VR3 Posts: 29,428
    edited January 2004
    I still think he outta look into NAD and AMC...
