MW8100 positive/negative?
attym
attym Posts: 33
edited November 2013 in Vintage Speakers
Maybe I'm not looking close enough, but which terminal is positive and which is negative?
Also, black wire positive?
Post edited by attym on
  • Schurkey
    Schurkey Posts: 2,122
    There's often a red paint mark on the + terminal of speaker drivers. If that's gone, connect a battery to the driver, see which polarity makes the cone move outward. I was always instructed to use a 9-volt job, but others recommend an ordinary AA, C, or D.
    Black wire is likely positive, since Polk tends to use white as the color-code for negative.
