too much tweeter noise
Systems
hey, i have a mm465 component system for my front and im am experimencing too much treble from the tweeter. if i try to decrese the treble notch, the sound end up mono like. but if i turn up the treble then too much tweeter noises and less vocal from the singer. is there anyway to adjust this to get the soft blending between tweeter and the midrange.
thanks
thanks
Testing
Testing
Testing
Testing
Testing
there should be a switch on the crossovers to change the sensitivity of the tweeter from " - 3 " to " 0 " to " +3 " ... chances are you're on +3 or 0 right now -- try lowering it to -3 see what happens.The Artist formerly known as PoweredByDodge
