Emotiva LPA-1 7 channel power amplifier (Auburn, WA p/up) - $450
jephdood
I don't have the box anymore and, so, I don't want to ship it. Excellent shape and operates as-new. $450 firm.
These had, if I'm not mistaken, a substantially bigger power transformer than any of the UPA amps.
SPECS:
Rated Power Output: (All Channels Driven @ 1Khz, 120VAC/ 60HZ supply, THD noted)
Channels 1-5 125 Watts into 8 Ohms (0.04%THD)
225 Watts into 4 Ohms (0.04%THD)
Channels 6-7 50 Watts into 8 Ohms (0.05%THD)
95 Watts into 4 Ohms (0.05%THD)
Frequency Response:
20-20Khz: +/-0.1dB
10-100Khz: +/-1.0dB
Total Harmonic Distortion (THD): (80kHz measurement bandwidth)
Channels 1-5: <0.040%
Channels 6-7: <0.052%
Signal-to-Noise Ratio: >100dB, Unweighted (Full Output Reference)
DC Offset: <1mV
Crosstalk: >75dB
Damping Factor: Approximately 200 into 8 Ohms
Input Sensitivity Range (Gain):
Channels 1-5 29dB
Channels 6-7 26dB
Input Impedance (RCA Input) 47K Ohm
External Trigger Input: 3-12 VDC, center tip of 3.5mm jack is positive
Clearance for ventilation (Back): Minimum 2" / 50 mm
Electrical Power Requirement: 1200 watts @ 115VAC when driven into 8 Ohms
Electrical Power Consumption: 4 Watts (Standby) and 46 Watts (Idle)
Raw Weight: 63lbs / 28.63kg
Shipping Weight: 70bs / 31.81kg
Dimensions: 17" W x 7.75" H x 19" D
432mm W x 197mm H x 483mm D
Pics available on request.
Thanks for looking.
-jeff
SPECS:
Frequency Response:
20-20Khz: +/-0.1dB
10-100Khz: +/-1.0dB
DC Offset: <1mV
Crosstalk: >75dB
Channels 1-5 29dB
Channels 6-7 26dB
Thanks for looking.
-jeff
"I did not slap you. I high-fived your face."
Post edited by jephdood on
pics please...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
