Laptop purchase
PSOVLSK
PSOVLSK Posts: 5,229
edited November 2013 in The Clubhouse
http://www.bestbuy.com/site/lenovo-g500-15-6-laptop-4gb-memory-1tb-hard-drive-black/2452185.p?id=1219072957875&skuId=2452185&cmp=RMX&ky=1vqvUDdwFJToQgiQMcLLGQtY9FMdNFzN7
Picked this up for my wife today. Early Black Friday deal for $399. Also had a $55 Gift Card and a $20 Reward Certificate, so not too bad I don't think.
I'm admittedly not much of a computer guy, so...good deal or not?
Post edited by PSOVLSK on
  • sucks2beme
    sucks2beme Posts: 5,606
    You are going to hate the win 8 interface.
    1ST thing I did was install the run interface.
    Lenovos are pretty nice even the lower models like this one. Have pretty much the same model with 8 gigs of RAM. Been running for almost a year. No real problems.
    The only complaint is the track pad is a little "too sensitive". Something that Windows 8.1 upgrade seems to have tweaked a little.
    You can pretty much "ignore" W8 if you want by migrating everything to the Desktop, and or pinning it to the task bar on the desktop.
    8.1 gives you a button that lets you access the live tiles and switch back and forth from the desktop. It also reproduces a button in the tile view that allows easy access to ALL aps. I suspect 8.2 will "return" even more familiar functions.
    BTW. That's a very GOOD price for this machine which normally sells at about $500-549 discounted?
    cnh
  • Irrenhaus
    Irrenhaus Posts: 1,092
    Hi
    That is a good deal.
    If you want to have the regular start button on W8.1 use Classic Shell works great on desktop mode. I use it on mine and like it.
    http://www.classicshell.net/
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
