255c-RT in-wall center inside gas chimney cavity (?)
eyedev
eyedev Posts: 18
edited November 2013 in Speakers
I have an oddly-shaped living room that only supported in-wall and in-ceiling speakers. I didn't want to compromise the most-important speaker by putting it in the ceiling so I am putting it above my TV in the wall. The TV is over our gas fireplace so the wall houses the chimney.
Here's the problem: the wall is not enclosed like a normal wall would be with drywall 4" behind the front wall. There's a large cavity of probably 36" behind it to give the chimney room on all sides. I'm not worried about the heat so much since the real 4" chimney is enclosed with a 6" pipe. The chimney also bends away from the speaker so only the elbow of the chimney is about 18" from it.
Should I build a box for the center? The box would easily be constructed since there's a 2x4 directly above, left, and right of the speaker. I would just need to add a bottom 2x4 and then screw in a piece of plywood for a back. I would probably put a piece of sheet metal on standoffs to block the infrared heat coming from the chimney too.
Think the speaker would sound better with a box in this situation? Aren't they built for a tightly enclosed space like a normal wall would be?
thanks
Post edited by eyedev on
  • eyedev
    eyedev Posts: 18
    I think I'll read the manual and then box it in like I said just with some insulation
    http://www.polkaudio.com/downloads/manual/DIY_inceiling_inwall_installation_guide.pdf
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I'm a bit worried about the fire codes to prevent a fire. May need to build wall behind speaker to prevent a fire from getting into living space.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    tonyb Posts: 33,065
    Better to use a thin on wall speaker than in-wall in that location. To me, your just asking for trouble going into the chimney.
