Marantz SR7300OSE
Jimmie
This receiver is like new. It has never been driven hard . It is a very musical receiver and great for movies. Have original box and packaging, manual and remote. Remote has lcd screen and will teach and learn. It is macro capable. Priced low for quick sale.
$725.00 includes shipping from zip 29732. Thanks.
Jimmie
bolin@comporium.net
Details:
The Marantz SR7300ose, a supercharged version of the Marantz SR7300, is designed for exceptional high-end home theater performance that incorporates DTS® ES-discrete 6.1-channel decoding for enhanced surround sound realism. The additional back surround channel decoded from DTS-6.1 encoded discs provides a more realistic surround sound environment by allowing smoother, 360-degree sound effects. For enhanced performance, the SR7300ose incorporates a copper plated chassis with double bottom plate, upgraded power supply, better shielding and wiring and gold plated input and output jacks. The Marantz SR7300ose also offers a selection of other useful surround modes, including Dolby Digital® EX, DTS® 5.1 decoding. Dolby Pro Logic II® (Music and Movie) decoding, an HDCD decoder, as well as SRS Circle Surround® II (6.1). The SR7300oses advanced DSP circuitry utilizes 24-bit, 192 kHz audio decoding and a leading edge Crystal® DSP chip for superlative fidelty and resolution. The SR7300ose is software upgradeable and easily controlled via a RS232C terminal and includes a programmable learning remote control.
Features
110 Watts x 6 (Into 8 Ohms)
All Discrete Amplifier Stages
192 kHz/24-bit D/A Converters For All Channels
Dolby Digital EX 6.1/5.1, DTS 6.1/5.1
DTS 96/24
Dolby Pro Logic II (Movie, Music)
6 Channel Stereo Mode
HDCD Decoder
Multi-room, Multi-source Capability
Speaker A/B Switching
Gold Plated Inputs/Outputs
Copper Plated Chassis With Double Bottom Plate
Several modifications to the Power Supply, Signal Path, Output Devices, Preamp Stage as well as improved internal Wiring and Shielding
Specifications
Software Upgradable (RS-232)
THX
DTS ES 6.1 Discrete/5.1/Neo:6 + DTS 96/24
Dolby Digital EX®
Dolby Pro Logic II
Circle Surround SRS CS® 6.1
HDCD Decoder
Current Feedback Topology
Discrete Amplification
Power Transformer EI (Upgraded)
D/A Conversion 192 kHz/24-bit (Hand Selected)
Digital Surround Processing Crystal® (Hand Selected)
Video Off
Source Direct
Chassis AllCopper w/ Double Bottom Plate
Customized Components
Shielding Extensive Shielding in all Critical Areas
Composite In - 5 (gold plated)
Composite Out - 3 (gold plated)
S- Video In - 5 (gold plated)
S- Video Out - 3 (gold plated)
Component In - 2 (gold plated)
Component Out - 1 (gold plated)
Analog In - 8 (gold plated)
Analog Out - 4 (gold plated)
Digital In - 7 Total
Digital Optical In - 4 (3 assignable)
Digital Optical Out - 1
Digital Coaxial In - 3 (assignable)
Digital Coaxial Out - 1
Pre- Amplifier Out - 7.1 Channels (gold plated)
Main Amplifier In
Multi-Channel In - 8 Channels (gold plated)
Multi-Room Audio Out - L/R Pre-out (fixed or variable)
Multi-Room Video Out - 1 (CVBS)
RS232C
DC Triggers - 2 (assignable)
Speaker Terminal A/B + C, Sl, Sr, Sb
Multi-Room Speaker Terminal
D-Bus RMC Out
Multi-Room RMC
External IR Yes - thru RC-5
AC Outlets Yes, (1 switched/1 unswitched)
Front Inputs L/R, CVBS, S, Opt. Digital
Headphone Out
Power Output (8 Ohm) 110 W x 6, (<0.08% THD, 20Hz - 20 kHz), SA-Ready
Signal to Noise Greater than 105 dB
Freq. Response (Analog In) 8 Hz - 100 kHz
Freq. Response (Dig In) 8 Hz - 45 kHz
Input Sensitivity 195 mV/47k Ohms
Color - Black
Front Panel - Aluminum
Remote Control - Learning with LCD - RC7300SR
Power Requirement - AC 120v / 60Hz
Dimensions Inch - W x H x D 17 5/16 x 6 3/8" 18 1/4"
Weight - 35.1 lbs
Jimmie
bolin@comporium.net
Details:
Features
DTS 96/24
HDCD Decoder
Specifications
THX
Dolby Digital EX®
Dolby Pro Logic II
HDCD Decoder
Video Off
Source Direct
Main Amplifier In
RS232C
D-Bus RMC Out
Multi-Room RMC
Headphone Out
Color - Black
Weight - 35.1 lbs
Post edited by Jimmie on
I have purchased items from Jimmie and have been very happy. Great communications, items were exactly as described, packaged well and was shipped very quickly. No problems with this seller! Too bad I don't need a receiver.
madmax
I have purchased from Jimmie before as well. I would make only one change to the above comment. The unit I received was VERY well packaged. -
Thanks for the kind words guys.I am humbled.
I sold a pioneer elite to a guy in Colorado. I had ups package it because I did not have the original box. You guessed it, they dropped it on the edge and bent the case and cracked the front face. I only insured it for 300.00. UPS sent it back to the local ups here and they called me to come over and apply for the insurance. After I looked at it I decided to bring it home and do some repairs on it. I have got it where it is hard to tell it was damaged but I cannot sell it this way so I decided to keep this one and sell the Marantz I have. Thats why I have the 7300 up for sell. I like the Marantz better but this pioneer elite works just fine so I will use it .
Again, Thanks for your very kind words.
Jimmie -
Just the facts...
*sigh* I missed out on that deal the first time.
Is there something functionally wrong with the elite now or do you just feel uncomfortable selling it after it had been damaged?
Good luck with selling the Marantz.
regards
DaveTime is the best teacher. Unfortunately it kills all its students. -
I would just like to say, Jimmie and I have made transactions before on more than one item, and I could not recommend a more honest and nice person to make a deal with, than Jimmie. He is very fair on pricing and every item has been in excellant condition. To anyone who may be considering this receiver or any items Jimmie may offer in the future... know that you are dealing with a very respectable individual. Good luck on the sale Jimmie, and I'm sorry to hear about the UPS ordeal with the Pioneer Elite.
Regards,
Terry -
Hi Terry,
Yes that was a let down. The elite works just fine though. The inners were not affected. I had it insured for 300.00 but after I looked at it I could not bring myself to let ups have it for that.
Hope you and the wife are doing good.
Jimmie
Yes, that's right Dave, I did not feel I could put it up for sale again even though it is fine other than a chip missing on the lower front of the face. It has worked out for me because I have tented doors on my component rack so it cannot be seen through the tent.
Jimmie
