Need input on rear speakers - on wall
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
edited November 2013 in Speakers
Right now I've got a pair of R15 bookies on stands for the rear, but would like to ditch the stands to free up the floor space back there. I'd like to go with an on-wall option, but want something low profile so the likes of an LSiFX aren't an option.
I've been looking at the OWM5 from Polk and think that's the general direction I want to go, as it looks like a fairly thin speaker and doesn't cost an arm and a leg. I want sound back there for effect, but am not too concerned with it being timbre matched to my fronts or anything like that. To get the best match I'd ideally go with the Magnepan on-wall, but that's overkill for my room and what I really want.
So I have a couple questions:
First off, are there any obvious choices similar to the OWM5 that I'm overlooking?
Secondly, do I have any decent options for running speaker cable up the wall to them? I don't really want to run cable up inside the wall, but if there's an easy way to do that without drilling big holes in the wall I'll consider it but I can't think of how that would work. I also don't want bare speaker wire hanging down from the speakers (in fact that's absolutely not an option). So I'm looking for creative ideas on how to hang these on the wall without the wires looking tacky.
Anyway, just looking for other ideas...
Post edited by AsSiMiLaTeD on
    EndersShadow Posts: 17,688
    What about the blackstones? Can those be wall mounted?
    Regarding cables, I would just run it outside and get some cable hiders (forget exactly what they are called)
    See my pic as I used them for my wires for the LSi F/X's
    Look at the doorframe in this picture:
  • AsSiMiLaTeD
    The blackstones sound great, but are not thin enough for what I want, I'm looking for the thinnest option possible.
    In ceiling? Otherwise the OMW 5's are probably your best bet unless you can find some of the VM floating around. Have you thought about Polks wireless speakers (forget model number)?
  • AsSiMiLaTeD
    Yeah I think the OWM5 and some sort of thing to hide the cable is my best bet...
  • rooftop59
    rooftop59 Posts: 8,121
    I think that if you could find one more of these you would get a step up in SQ with just a little deeper profile: http://www.ebay.com/itm/POLKAUDIO-RM7500-Black-CENTER-CHANEL-Speaker-Polk-Audio-Tested-Working-/221315858886?pt=Speakers_Subwoofers&hash=item33877401c6. They pop on fleabay pretty regularly.
    I am assuming no attic in the condo? I love my stealth in-ceiling setup, it sounds good looks really clean and really isn't hard to do.
    Game Room 5.1.4:
    Bedroom 2.1
  • zane77
    zane77 Posts: 1,696
    You can use some beaded metal chain to run the speaker wire in the wall just a small hole where it will come out and hang the chain so you can mark a spot where you want the speaker cable to come out. Drop the chain down the upper hole and hook it out of the bottom hole then attach the speaker wire to the chain and pull it up to the hole where the speaker is. Small holes and hidden wire the way to go.
    Two Channel
