B&K CS 117 phono section or not??
geppy1
Does a B&K CS 117 preamp have a phono board from the factory or is it an option?? thanks
Post edited by geppy1 on
It's an option. Not a bad pre-amp if you use it in the passive mode, but if you're thinking about buying one, make sure you can test it out in your system & the sound works for you.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i
