Creative VideoBlaster MovieMaker, convert VHS to CD.
Ceruleance
This device works well for transfering VHS tapes to VCD's that can be played on your DVD player. (or if you have a big hard drive you can just store the MPG files) It works by converting an S-video or composite input and then sending it to your computer via USB.
VHS tapes wear out, CD's not so much. I have transferred all of the VHS tapes I care about to CD and therefore I have no more use of this product. The quality of the transfer is certainly good enough to capture VHS, but don't expect to pirate DVD's without some loss.
You can read all about it here:
http://us.creative.com/products/product.asp?category=60&subcategory=96&product=13&nav=features
I have all the included contents, no box though.
$50 + shipping takes it.
