sda 2.3
ktmken
I have sda 2.3 speakers and want to upgrade them. They have the old style donut drivers. What is everyone doing to upgrade them? I love them and have not used them in years. They will be a part of my home theater and listening room.
Post edited by ktmken on
Upgrade usually doesn't involve mid woofers unless they are bad/frozen.
Crossover, tweeter, dynamat driver baskets, seal cabinet, epoxy mid woofer magnets, spike cabinet etc...
The doughnut drivers if they work are good leave them the intention was to enhance the bass response.
Start by replacing the tweeters with RDO-194 they are much better than the Sl-2000. Next will be the tired old out of date dried out crossovers, only the capacitors and the resistors will need to be replaced.
start reading this http://vr3mods.com/uploads/SDA_Handbook_2011_Rev2.pdfPOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
See my sig - mine are the 2.3TL's, but most of the mods would apply to your speakers as well."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
