Pioneer SC-63
LeftCoast
LeftCoast Posts: 410
edited November 2013 in Electronics
Hey, folks. I plan on turning a bonus room into a home theater room with some nicer, higher end equipment.
Downstairs in the living room, I was planning to do something more modest...not a full on rig. A 50" LG Plasma TV, and a spare Polk Cs400 center. I'd just have to look for a couple of speakers and probably keep it at 3.1 setup.
So today, I saw an open box Pioneer Elite SC-63. Missing power cord and remote. Price - A good bit under $500.
A price point to consider, or is this overkill, and I should find something less expensive?
Post edited by LeftCoast on
    F1nut Posts: 52,033
    Without the remote it's basically a boat anchor.
  • LeftCoast
    Just looked it up...$56.75 for a remote....Puts the total cost of it in the low $500's.
    F1nut Posts: 52,033
    LeftCoast wrote: »
    That's cheap enough. What about the mic?
  • LeftCoast
    Right...didn't ask.
    Maybe I could talk them down some more on the price :)
  • LeftCoast
  • Nightfall
    Nightfall Posts: 10,083
    Do the mics do anything someone can't do manually with an SPL meter?
    afterburnt wrote: »
    Village Idiot of Club Polk
    It's not the mic itself, it's the auto calibration that needs the mic. Yes, you could do it yourself and usually you'd have to tweek the settings anyway after the auto calibration. In the end, you use settings that sound good to your ear anyway.
  • badchad
    badchad Posts: 348
    Can you use different mics for calibrating different receivers? If so, you might be able to wait until you set up the bonus room, and use a the mic from that receiver. Personally, with 3.1 I'd settle for doing it by ear, as that's how it'll end up anyway.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
    badchad wrote: »
    Good question, I'm not 100% on it, but I would think the software for the auto calibration in a receiver is also calibrated to be used with a certain mic. Using a different one may....or may not throw it off some.
  • WLDock
    WLDock Posts: 3,073
    For the SC-63 unit:
    Mic - AMP7010 - $27.36
    Remote - AXD7666 - $40.13
    http://parts.pioneerelectronics.com/model.asp?modelNum=SC-63
  • LeftCoast
    WLDock wrote: »
    For the SC-63 unit:
    Thanks, WLDock
    So what do you think, guys? Would this be a good pick up?
    If that comes with a full warranty I'd say go for it!
    cnh
  • LeftCoast
    Thanks!
    I will ask about the mic, though, and try to talk them down some more...Maybe ask that tax be included or something :)
    nooshinjohn Posts: 26,009
    Are you getting this from Paul's
    I Got my SC65 from them at a stupid price as well. Looking to grab an Elite N30 network audio streamer as well for 150 bucks!
  • LeftCoast
    John
    Open box and BB. So full warranty.
  • codyc1ark
    codyc1ark Posts: 2,539
    Go get it before it's gone.
    pitdogg2 Posts: 27,376
    tonyb wrote: »
    usually not unless you calibrate to the unit...My 3805 did have instructions that you would use to calibrate A non Denon mic.
  • polrbehr
    polrbehr Posts: 2,852
    LeftCoast wrote: »
    Thanks!
    Don't wait too long, this seems to be a no-brainer.
    And definitely try to talk them down some more. I got $30 off a Denon 3312ci already marked at $479, no manual or power cord either (big deal, the stock PC gets rubber-banded and thrown in my junk drawer anyway...). The fact that the remote was missing also gave some leverage, but the kid in the Magnolia room found a Denon remote for me to try, so I took it home; would up with a remote for a 43xx series that does even more than the OEM one did.
  • Dabutcher
    Dabutcher Posts: 2,606
    bought my SC 63 a month ago from Newegg brand new $599.99. aditional two year warranty for 29.99. love it!
  • Zoomzilla
    Zoomzilla Posts: 76
    Jump on it. I have never used the remote for my 63 I bought recently. I love this thing!
