TT help needed. Sony PS 210
Dabutcher
This is one of my nicer TT's and sounds great . Seems to only start to spin platter when it is a quarter of an inch into first song? Any and all help would be greatly appreciated. I am starting to get more serious about vinyl . I bought a scale and protractor to finally start a proper set up. Thanks. Darryl
Post edited by Dabutcher on
Hi Dabutcher..
Did this just start happening?
Does the arm feel a little loser than before?
Might need an adjustment under the arm..ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
Yea it needs an adjustment with the shut off, it thinks it is at more than 6 inch radius from the center spindlePOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Been doing that since I bought it.MIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
Well, either the shut off or the turn on, methinks! :-) Most Japanese tts of that era had a microswitch that started the platter as the arm is swung from the rest position towards the platter. It should turn on just before the stylus crosses over the threshold of the platter. Presumably one (or more) of the position sensing switches needs to be adjusted.Yea it needs an adjustment with the shut off, it thinks it is at more than 6 inch radius from the center spindle
I just checked www.vinylengine.com and they don't have any docs for this particular Sony (nor am I familiar with this particular tt)... I'd suggest downloading a few of their Sony DD tt service manuals and peruse the instructions therein for adjusting the position sensors/microswitches. I imagine (I guess that I hope) you'll be able to figure out the procedure for this tt by analogy. -
There may be an adjustment screw for this. On my Sony PS-X75 Biotracer table there is a small screw located within an access port on the top of the plinth near the tone-arm. There is a rubber plug that covers the access port so the adjustment screw is not readily accessible. Simply remove the rubber plug and the screw (standard slot) is revealed through the access port You can turn the screw so that it adjusts where the tonearm falls on the record starting playback during automatic mode. Your particular table may have a sensor that starts the platter only after the tonearm gets in the proper lead-in position in automatic mode. Have you tried operating the table manually and does it still do this when you operate manually?
Edit, doesn't look like you can start the platter manually does it? I think is has to be either an adjustment issue as discussed above or a sensor that starts the platter may be faulty. Oh one other thing, on my Biotracer if the VTA of the tonearm is not set-up properly with the tonearm being parallel or close to parallel to the record surface during operation, the tone-arm will not operate during autostart mode. It's a protective feature to keep from damaging the stylus. Check your tone-arm level and make sure it is parallel to the record during playback. That may be throwing the autostart sensor for the platter out of whack. -
Went into the back and activated the switch a bunch of times and moved lever back and forth and now it seems to start at the right spot. Thanks for the help. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
