Answer about medals:
sgtgto
sgtgto Posts: 310
Need an answer from AF guys out there:
If you had four medals, Good Conduct, Marksmanship, Air Force longivity, and National Defense. What order would you wear them.
I have been out a long time and want to make up a military box. These are all bar ribbon medals.
George, you should know this.
Gary
  • TroyD
    TroyD Posts: 13,124
    edited December 2001
    Gary,
    From bottom right (if you are facing them): AF Training ribbon (that is a gimmie) Small Arms Marksmanship, AF longevity, Nation Defense, Good Conduct. In that order.
    Also, you could possibly contact the VA and get a copy of your ribbons/decoration report. At least now, when you separate they will award you an achievement or commendation medal.
    If you need any of the ribbons or medals, let me know and I can get them for you.
    Troy
  • sgtgto
    sgtgto Posts: 310
    Hi Troy:
    Thanks a lot. They didn't have the training ribbon when I was in, 1962-69. I don't know if I am authorized to wear that or not.
    I can get what I need at the Army Navy Surplus store here, thanks for the offer. And I have my DD form 214 so I have all of my medals on that.
    Gary
  • TroyD
    TroyD Posts: 13,124
    No worries......
    I'll look in to the training ribbon but if I am not mistaken, if you graduated from Basic, you should be authorized to wear it. I will double check however.
    Troy
