Amp and/or Preamp problem
rromeo923
rromeo923 Posts: 1,513
edited November 2013 in 2 Channel Audio
Amp= Conrad Johnson MF2200 (solidstate)
Pre= Conrad Johnson PV2 (tube)
When I turn on there is no sound for about 30 seconds or so. Then it kiicks in. Previously it was doing this but only in left channel.
After sound starts all is fine.
Any ideas??
I got static in my head
Post edited by rromeo923 on
  • michaeljhsda2
    michaeljhsda2 Posts: 2,185
    Cold solder joint somewhere?
    SDA SRS 2.3TL's
    SDA 2B TL's
  • gmcman
    gmcman Posts: 1,807
    How long have you had the preamp? Reason I ask is some tube equipment need a brief warmup.
  • rromeo923
    I have had the preamp for a year or two. I always turn on the pre first. I turned on and then waited a few minutes till I powered up the amp and still problem. I think it is the amp.
  • gmcman
    gmcman Posts: 1,807
    Any way you can swap an amp or a preamp? I haven't used any tube equipment but could this be a tube going out?
  • Msabot1
    Msabot1 Posts: 2,098
    Let the pre warm up 30 minutes before turning on the amp...tubes need to get to ramp up their temp before they can operate properly. That might be the whole prob.
  • skrol
    skrol Posts: 3,391
    Is there a relay in the amp circuit? Relays have a tendency to age and can cause such symptoms due to dirty contacts or mechanical wear or sticky lubricants.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Glen B
    Glen B Posts: 269
    Definitely sounds like a problem with the amplifier output relay, or aging component in the relay driver circuit.
  • BlueFox
    BlueFox Posts: 15,251
    rromeo923 wrote: »
    This could be normal operation, and when only the left channel was doing this then that was wrong. My Cambridge-Audio 840W amps were the same way. Turn on, and they went through some initialization phase before starting to play.
    F1nut Posts: 50,734
    I thinking a relay problem as noted by skrol and Glen B.
  • headrott
    headrott Posts: 5,496
    Yep. Relay in the amp.
