People who know the Outlaw 950 pretty well...
starkiller
starkiller Posts: 2,723
edited November 2013 in The Clubhouse
please send me a pm. Think i got the VCR sorted out. Tried the blu-ray player next and while it shows a nice picture on the plasma there is no sound. I tried the cd player next and the sound was very nice so at least those connections are correct as far as the back of the 950 goes. So..what am i doing wrong..still..:(
Would go through the OUtlaw forum but not alot of activity there...
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
  • ohskigod
    ohskigod Posts: 6,502
    how do you got the blueray player hooked up....digital? gotta configure the digital inputs. and last I remember, I think you gotta use the menu through a TV screen to do it (at least thats the way the 990 is)
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
    tonyb Posts: 33,015
    The outlaw, if I'm correct, doesn't do the new BR codecs. Some BR disc also don't have a DD/DTS soundtrack either and a lot of BDP's these days don't have 5.1 pre-outs. To get the newer codecs into the outlaw, you would need a player with analog outputs.
    Time to go shopping, upgrade that outlaw.
  • ViperZ
    ViperZ Posts: 2,046
    tonyb wrote: »
    Deleted. My apologies to tony, he is correct, as 950 has no HDMI. I haven't looked at the back of 950 for a while...
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
    pitdogg2 Posts: 25,700
    ViperZ wrote: »
    while they do not have HDMI they do have DVI and they sell HDMI to DVI cord
  • rooftop59
    rooftop59 Posts: 8,121
    950 has no DVI, only component. What bluray player is it, and are you using a digital connection or multi-channel analog outputs? I disagree with Tony that it is time to upgrade the pre. Get on ebay and get a Sony BPD-S550 that has multi analog outputs and converts everything internally. You can get it for less than 100 bucks. The sound will be very good on the cheap.
    Game Room 5.1.4:
    Bedroom 2.1
    sorry guys thought it had DVI. I remember looking at one that did have DVI
  • rooftop59
    970 and 990 have DVI, and I think everything after that has HDMI. I have thought about picking up a 950 on ebay because sometimes they go for as little as 100 bucks in good condition, but with an (almost) all in-ceiling HT the necessary amps would be a waste of money...
    Game Room 5.1.4:
    Bedroom 2.1
    tonyb Posts: 33,015
    rooftop59 wrote: »
    True, he can go that route. However, using the analog outputs also has it's disadvantages. If one speaker goes down, some BDP won't allow you to re-route that portion of the signal like a receiver/processor can, so that info is lost. Plus that's 6+ more cables to buy which also add up. Having HDMI compliant gear limits the cables needed and also allows for other gear to be easily compatible.
