Need help as usual :( Hooking up VCR to Outlaw 950
starkiller
starkiller Posts: 2,723
edited October 2013 in The Clubhouse
Redoing entire h/t sytem which necissatated unplugging all wires, taking items off the towers and moving them to a single low-boy. Now can't figure out/remember how to wire the vcr! The VCR has 3 jacks...audio--left and right and one video jack. The Outlaw has Y-PB and PR, so, which jack goes to what? This is so frustrating to forget and also not to know, memory loss from complications of diabetes and such has really ruined the 'ol memory bank :(
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
  • starkiller
    edited October 2013
    One thing i forgot (imagine that), the VCR will only be used for playback..no recording.
    mhardy6647 Posts: 34,003
    edited October 2013
    That video jack is standard NTSC composit video; looks like the Outlaw should (somewhere?) have an RCA composite video input jack but the ones you're looking at are for chrominance and luminance component video inputs.
    Taken from:
    http://www.outlawaudio.com/products/950.html
    manual for 950 at: http://pdf.outlawaudio.com/outlaw/docs/950manual.pdf if you don't have one.
    EDIT: Oh, yeah, "VIDEO 1, 2, 3" are composite inputs - see pages 8 and 9 of the manual (feature number "13" on the back panel)...
    EDIT^2: or the "VCR jacks" :-P (Feature number "14").
    Video Section
    Composite
    • Video Format: NTSC
    • Input/Output Level: 1 volt P-P
    • Input/Output Impedance: 75W
    • Frequency Response: 5 Hz - 10 MHz -- +0, -3 dB
    S-Video
    • Signal Format: NTSC Y/C
    • Luminance (Y) Input/Output Level: 1 volt P-P
    • Chrominance © Input/Output Level: 0.3 volt P-P
    Component Video
    • Signal Format: NTSC Y/Pr/Pb
    • Analog Components
    • Pr Input/Output Level: 0.7 volt P-P
    • Pb Input/Output Level: 0.7 volt P-P
    • Frequency
    pitdogg2 Posts: 25,700
    edited October 2013
    you will need to hook that into a red(right) black(left) and yellow(video) ...the pretty ones you describe are component and will match the device it is coming from. They carry red, blue and green colors and put them back together inside the outlaw950. you will get all kinds of funky stuff if you try to put your VCR into those RGB's
  • PSOVLSK
    PSOVLSK Posts: 5,231
    edited October 2013
    What's a VCR? :)
  • Msabot1
    Msabot1 Posts: 2,098
    edited October 2013
    Those are component outs to ins..just match color on jacks to in or out and you're in there!
    edited October 2013
    PSOVLSK wrote: »
    What's a VCR? :)
    They're really handy; I use one to record HiFi analog audio in FM :-)
    holidaydubbing121209 by mhardy6647, on Flickr
