Phantom Center: Pros/Cons
falconcry72
falconcry72 Posts: 3,580
edited October 2013 in Speakers
I have started to give more attention to my HT system. I've been experimenting with many types of speakers, and I am currently using Usher Audio Dancer Mini 2 DMD's for fronts and an Usher Audio BE-616 DMD as a center. They match great, and this center is tied for the best center I've ever heard (along with the LSiM-706).
As good as this center is, the system sounds better using a phantom center... from the sweet spot. This center uses an identical tweeter as the fronts, and with Audyssey you can get real close to perfect timber and level matching, but it will never be as perfect as using the fronts to reproduce the center signal... as long as you're in the sweet spot. From outside the sweet spot, I prefer using an actual center to anchor dialogue and add to the 3D soundstage.
Another consideration is amplification. I am currently using a 5-channel amp. If I went with a phantom center, I could use a receiver to power the surrounds, and then sell the 5-channel amp and replace it with a higher quality 2-channel amp just for the fronts, for the same cost. 2-channel amps are more common and would give me more amplification options.
What do you guys think?
Post edited by falconcry72 on
  • Face
    Face Posts: 14,340
    edited October 2013
    Because the center being a MTM is a poor design and lobes off axis. Unless you can fit a third Usher Audio Dancer Mini 2 DMD in the center, it's very possible a phantom center will sound better.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited October 2013
    I think for HT you have to and must gear it around the center channel. Phantom shmantom as your never going to really localise that pan like you can with a center ch. I think if your not happy with the center than start again and go for a system that has a monster center and get that tower power from your dialogue
    nooshinjohn Posts: 25,926
    edited October 2013
    If you have a stereo pair that image very well, as I understand the Ushers do, there is no need for a center. I find with my rig, the other surround locations are simply not needed with the big SDA's at all. I have yet to take the time to even set up the surround locations at all.
  • RamZet
    RamZet Posts: 792
    edited October 2013
    I would only use the phantom center if it was my only option. If for some reason you cant get wire to your center speaker location or if you didn't have room for a center speaker. It doesn't sound bad but if you want it to be correctly done i would pass on it and get a center.
    But if you think it sounds better in phantom mode then go for it. As long as your system sounds good to you.
    B&W CM9Classé Sigma
  • pearsall001
    pearsall001 Posts: 5,294
    edited October 2013
    If you're gonna do it...do it right, center speaker all the way.
  • Conradicles
    Conradicles Posts: 6,343
    edited October 2013
    Phantom is cool in the sweet spot, but a center is needed to get proper sound to other locations in the room. If you are the only person who ever watches TV and you sit in the same spot every time, go for the phantom.
  • WLDock
    WLDock Posts: 3,073
    edited October 2013
    I think it depend on what side of the fence you stand on.
    Yes, you could go all out 2 ch and just rock that and say the hell with all the surround formats. It works....even in a pinch. I did it myself with some very basic KEF egg speakers and a small sub. It sounded a million times better than dealing with the oem tv speakers until I got a better system together. With the Uni-Q drivers, dialog was well rendered at all seats on the couch and pretty well centered with good L-R pan.
    Once, I finally got a full surround setup...i.e.. BIG SOUND to match the BIG SCREEN things changed. Running two channel with the 48" tall towers of cource brings the sound up a bit. However, running a 5.1 setup in Dolby TrueHD was a whole new experience! Yes, we all wish the center channel was in the center of the screen. However, with a large screen the only choice to try get get dialog up is to angle the center and try different surround formats. Yes, angle your center! Find the right angle or sweet spot to hit your ears. DIY might be the way to go as the angle one needs will vary.
    IMO, Emotiva makes a nice pedestal: http://shop.emotiva.com/collections/accessories/products/xrcs1
    So, be happy with a 2-in-1 system...or pick the side of fence you want to stand on! The 2 ch vs. HT battle has no end in sight!!!
    tonyb Posts: 33,072
    edited October 2013
    There is no right or wrong answer to this. Everyone's room,gear, and ears are different. Personally I haven't use a center in about 8 years and haven't missed it at all. Depends on how well your fronts image. Try it first with a wide range of source material, no harm no foul either way and doesn't cost anything to try.
  • Emlyn
    Emlyn Posts: 4,708
    edited October 2013
    The only speakers I've happily used with a phantom center have been SDA 1C's and 2.3TL's. Panning effects and dialogue worked well with those. I removed the center speaker (LSic) I had because it wasn't needed with the SDA setup. Any other conventional front end speaker set up I've tried has fallen short of that experience in terms of trying to get by without a center speaker. I've been using a center channel speaker slightly angled upwards to the listening area for a few years now with JMlab speakers that image exceptionally well for the stereo pair, but don't come up to satisfactory performance levels for home theater without the matching center channel in place.
