Vintage Home Theater Setup
Huh What?
Huh What? Posts: 55
edited October 2013 in Vintage Speakers
I'm hoping to have room in the very near future for a second HT setup to use for movies exclusively. My current setup (Talon speakers, Simaudio, etc.) will serve double duty as HT and 2-channel listening. I'm sure I'll play around with the speaker setup, but wanted to get the forum's feedback.
I'll be using a pair of SRS 2.3's for the fronts. I have one pair of Monitor 10's and one pair of Monitor 7A's. The receiver is an NAD T775. Would I be best served using the Monitor 10's for the surrounds and one of the Monitor 7A's for the center channel? Given the importance of the CC in HT, maybe the Monitor 10 would be the better center channel and the Monitor 7's as surrounds. The Monitors have Peerless tweeters. I'm also open to suggestions for a different center channel and use the 7A's for back surrounds.
Home Theater - Talon Firebird (Fronts), Talon Raven 2002 (Surrounds), Talon Cinema Hawk (Ctr), Talon Falcon (Back Surrounds), JL Audio Fathom F112 Sub
Pre/Pro - Classe SSP-800
Amps - Sim Audio Moon Titan 5 channel, Modwright KWH 225i
Blu-Ray - Oppo UDP-203
Projector - Epson PowerLite Home Cinema 5040UB
Screen - Silver Tickets MPT 110"
Primary 2 Channel - Talon Firebirds
Modwright KWH 225i Integrated Amp
Oppo BDP-103, Audio Research DAC 8
Secondary 2 Channel - Polk SDA 2B
NAD T775, Denon 2900 DVD-A/SACD
Post edited by Huh What? on
  • StantonZ
    StantonZ Posts: 447
    edited October 2013
    I think you have a good plan; you can see from my sig I do something similar (using Monitor 4's as my CS). The 7's should be fine for a center channel: you want it to be strong in the mid (dialog) range, not the bottom end.
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • Mystery
    Mystery Posts: 2,546
    edited October 2013
    It's not a big deal to swap 7's with 10's since you already have it.
    Just set them up and listen.
  • Boonaroo
    Boonaroo Posts: 57
    edited October 2013
    I ran dual monitor 7's as my center in a HT rig. It worked great.
  • Huh What?
    Huh What? Posts: 55
    edited October 2013
    Thanks for the replies. I was thinking just one of the monitors for the center channel. For those of you running two monitors, do you have them wired in series or parallel?
