Where to put subwoofer
boston1450
Im going to hook up 3 channel HT. With 2 towers for fronts & a center speaker. I want to use a subwoofer but space is a problem on that wall..which i will be facing on my couch..would putting the sub on the other wall beside my couch be a problem as there will be no rear speakers.. Would the bass be too much for me sitting down & watching a movie.. Havent tried it yet but thought id ask here ..any thoughts TIA
Post edited by boston1450 on
Don't see why it would be a problem. A lot of people prefer to have their sub next to the seating position. Ideally you could do a "sub crawl" to find the optimal location but for us real world "HT-in-the-living-room" folks that isn't always practical.Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
HK AVR635 | Polk R30 | Sony DVD/SACD Player -
When i get a chance i will try it.i figured someone might have done it before..thank you..
Try the different locations that you can. They are all likely to sound pretty different. You will find one that covers the room best. Also try different distances away from the wall within the same location. I was surprised to find that a corner but 1.5 feet away from each wall very close to the couch worked best in my living room.Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
Might need to flip the phase switch on sub if you put it beside or behind couch.Speakers: SDA-1C (most all the goodies)
Great suggestion all. I will keep those in mind & i hope it works out. I do have some rear speakers but till i get a better receiver (yamaa 80wpc to fronts & center-15wpc?rears) i will use it 3 channel...THANKS..
