More bass from Ti400
stevenz20032
stevenz20032 Posts: 4
edited October 2013 in Speakers
HI, is it safe to run reciever below 80hz to get more bass from Ti400 speakers.
I have surround sound but no sub
Post edited by stevenz20032 on
  • ken brydson
    ken brydson Posts: 8,981
    edited October 2013
    If you don't have a sub run them full range. Just be careful with the loud knob. You're more likely to clip a tweeter than a woofer. What receiver are you running?
    Oh yeah, welcome to CP. Check your wallet at the door. We are REALLY good at spending OPM!!!
  • stevenz20032
    edited October 2013
    Thanks Ken, I have a denon AVR791. buy full range do you mean all the way down to 36hz or what ever it is
  • jbooker82
    jbooker82 Posts: 1,627
    edited October 2013
    There should be a full band setting, or a place to say sub - no.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Phasewolf
    Phasewolf Posts: 514
    edited October 2013
    It may say something like large when you select the mains that will set them to full range. Good luck and welcome to the site. And if you need ideas on how to spend money were there for you....... I am about to spend $1400 on a Parasound amp.
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
  • drummer86
    drummer86 Posts: 441
    edited October 2013
    Set the front speakers to Large to cancel the crossover setting. Make sure the subwoofer is set to off if you don't have one connected.
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
  • ken brydson
    edited October 2013
    Everyone else beat me to your answer. Try their suggestions and post back on the outcome...
  • stevenz20032
    edited October 2013
    Thanks for the help guys. Ill let you know how I get on
