In-Wall Speaker Help
Jadiesh
Jadiesh Posts: 2
edited October 2013 in Speakers
Looking at going completely in wall (except maybe Sub) using all Polk components. Wondering what the complete top of the line set up would be 7.1 for in-wall. Cost not really a worry. Looked last year at doing this however a lot of the components are no longer available
  • drummer86
    drummer86 Posts: 441
    edited October 2013
    Definitely wouldn't go in-wall for the sub. Everything else should be ok if it's what you really want. Is this for a dedicated theater? Just curious what your motivation is for going in-walls.
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
  • Jadiesh
    Jadiesh Posts: 2
    edited October 2013
    It is a dedicated room however space is the main reason. Are in walls that bad?
