Center channel speaker Polk 15C
Looking to replace most of my speakers, and my biggest issue is the center speaker. My entertainment cabinet which we purchased about a year ago has a limited space of 18" wide x 6.5" high x 15"D twice (side by side)for the center speaker. I wanted to get the Polk 15C center but it is listed as 7" high, is this correct and I assume there are no feet that can be removed to give me the extra 1/2". Is there any other Polk center which would work well and what are the draw backs? I recently purchased a Yamaha TSR6750 rated at 105 watt x 7 and thinking of getting the Tsi300 or 400 or monitor 65T for front with PSW10 sub. Any suggestions, thanks!
Post edited by Ppistilli on
Hello and welcome,
You could go with the CS10 it's 6 1/2" high and is timbre matched to the TSI 300 as well as the same construction. -
Never mind I see the space you have is only 18" wide and the CS10 is 20" wide. Is it possible to remove the sides or otherwise alter the unit to fit your CS in?
