AudioSource amps
Pauly
Do they make quailty amps? just wondering since i have been seeing alot of them in ubid lately.
Life without music would♭
Post edited by Pauly on
Yes, they make VERY good amps in their price point, and if you shop around (ubid/ebay) you can get them for less than $1 a watt.
Great entry level seperates, big toroidal power supplies, high damping, and ample headroom. Very nuetral sounding, and can drive low impedance loads. I use an AMP One / Pre One combo for the whole-house rig right now, and it works and sounds great. The 5.x series are great little monoblocks too, and make great sub amps, lots of built-in features. I have a 5.1 amp I got for $50, waiting on a back-loaded horn sub project.
I'd recommend them over the entry level HK Pa series, and Onkyo 51xx series that you also see so much of.
Cheers,
I used to be pretty skeptical about Audiosource, but after listening to a couple models in their line-up, I'm impressed. Alot of bang for the buck.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
I concur, probably the best value in entry level separates, IMO.
Good deal. Looks like i'll be shopping around for one for my 2ch
Thanks for the inputLife without music would♭ -
I've got an Amp One I'd be willing to sell. It's the original Amp One with the power meters. The meter bulbs are burned out but you can replace them. The meters work fine and the unit is in excellent working and cosmetic condition.
$110 shipped.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
I'll post some info and pics when I get home.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
