Tweeter "rattle" - replace or fix?
cjcinkc
cjcinkc Posts: 10
edited January 2004 in Speakers
:confused:
I have a "rattle" in one of my tweeters that's bugging me and needs to be replaced or fixed. I saw the ebay auction for the SL3000 and was just wondering if I can swap them for the SL2500, or is the rattle repairable? I only notice the rattle at higher power (-35db or better) and typically on vocals and brassy audio sections (4k Hz range) .
Thanks -
Chris
My little system:
Rcvr/Amp: Yamaha RX-V2400 (6.1)
Front: POLK Monitor 5A (27 years old and still pumping!)
Rear: POLK FXi3
Sub: POLK PSW150
Vid: Samsung Tantus 32" HDTV
Post edited by cjcinkc on
    F1nut Posts: 52,242
    edited January 2004
    Welcome to the forum.
    The rattle can not be fixed, so the best thing for you to do is buy the Polk replacement for the SL2500 and replace both of them. The SL3000 will not work in your speakers.
  • cjcinkc
    cjcinkc Posts: 10
    edited January 2004
    Thought it worth a shot...
    My little system:
    Rear: POLK FXi3
    Sub: POLK PSW150
