Amp Power for the Fronts
Early B.
Early B. Posts: 7,900
edited January 2004 in Electronics
Any benefit to getting a separate amp to power the fronts (Rti70's)?
I currently have an 80 watt receiver that works well for the size of my room and my listening preferences (translation -- not too loud). Sounds great to me now, but would it sound even better with a separate 2-channel amp powering them?
"God grooves with tubes."
Post edited by Early B. on
  • danger boy
    danger boy Posts: 15,722
    edited January 2004
    it will sound slightly better. more power will always do good for speakers.. the question is.. does your receiver have pre amp outputs or not? You can't use an external amp if your receiver doesn't have pre outs.
    PolkFest 2012, who's going>?
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2004
    I'll disagree here db....
    EB,
    If you are a low level listener and it sounds great to you, sit back and enjoy. I would not rush to add an amp.
    What your music/ movie split for your rig?
    More later,
    Tour...
    Vox Copuli
  • danger boy
    edited January 2004
    Tour, what is there to disagree about? everyone here knows i'm right. :p
    I'm writing this from experience. I have a 70wpc high current receiver. I always thought that it was being taxed running 5 speakers only putting out 70wpc. I would think Early B's 80wpc is not much different. we have the same fronts.
    I decided a year ago to add a 125wpc high current Adcom amp for the fronts.. i DID notice a difference in sound quality with the increase in power from the amp. no longer did the receiver have to power all the speakers.. it's load was greatly reduced by adding external amps. fact has taught us that an increase in power from an larger amp usually means better sound quality.. usually. there are of course other factors.
    if the increase didn't make any difference. we'd all be running 50wpc amps. ;)
  • Early B.
    edited January 2004
    I have a Denon 1803. If I'm understanding the manual correctly, the receiver has pre-amp outs for "Zone 2". I'm wondering if I can use the Zone 2 to connect an amp and power the fronts on them.
  • Tour2ma
    edited January 2004
    db,
    You know I agree with you in general and you may well be right here, but I don't recall you being a low level listener.
    More later,
    Tour...
    Vox Copuli
  • organ
    organ Posts: 4,969
    edited January 2004
    If you like to listen at high volumes you will hear a BIG difference.
    Maurice
