Home owner's and home owner warranties guru's needed!
starkiller
starkiller Posts: 2,723
edited October 2013 in The Clubhouse
Just noticed water seepage in the ceiling in our hallway of our top floor. Popped the attic access panel and the blown-in insulation on top of the seepage is wet and right above that, in the ceiling, is one of those attic vents...so obviously the rain has blown in and dripped down onto the insulation and then into the ceiling. Wouldn't our home warranty cover stuff like that...especially here in the rainy Seattle area i would expect them to guard against rain getting into the attic...??
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
  • rpf65
    rpf65 Posts: 2,127
    edited October 2013
    Your deductible will probably be more than repairs, unless you need a complete roof replacement. Do you see any damp spots on the roof decking?
    gudnoyez Posts: 8,174
    edited October 2013
    What type of home warranty is it? sounds like a little black roofing cement the Red Devil brand or OSI and a putty knife should do the trick if its leaking around where the vent is. Is the house new and the contractor gave you a warranty with it when it was built? If not and the damage is worth contacting your insurance company then do so.
  • ken brydson
    ken brydson Posts: 9,024
    edited October 2013
    Home warranty or homeowner insurance?
  • starkiller
    edited October 2013
    Will try the home warranty route first as i have a call into Quadrant Homes about the issue....
  • hochpt21
    hochpt21 Posts: 5,423
    edited October 2013
    That's what I was going to say. In Wisconsin, you can buy a house with a one-year home warranty if written into the offer from the seller. There is only an $80 deductible per service, but they are limited on what they will cover.
    Homeowners insurance would be separate from that.
  • nguyendot
    nguyendot Posts: 3,594
    edited October 2013
    Here the warranty is generally given for 1 year from the builder (it's expected). No deductible - just if it's broke they fix it. Beyond that you can get AHS (American home shield). Those cover major appliances, plumbing, electrical. It does not cover roof or foundation.
    Beyond that and in a totally separate category is your homeowners insurance. That varies from state to state and generally does not cover wear and tear. The roof has its own provisions. Here people have their roofs replaced all the time due to wind and hail damage.
    Main Surround -
  • jbooker82
    jbooker82 Posts: 1,627
    edited October 2013
    Seen an episode of Holmes on Homes where a couple had bought a new house. They had a problem with water / snow in the attic and it was caused by cheap vents. They would have to scoop the snow on to tarp and carry it down.
    What kind of vents do you have? sofet, vents cut in to the roof, or ridge cap vents?
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
