DIY speaker cable terminations
Early B.
Early B. Posts: 7,900
I'm looking to make a bi-wired speaker cable for my Rt-70's. I have Canare Star Quad cables that are currently terminated with screw-on type banana plugs. They're OK, but they get loose easily.
What's better -- DIY soldered banana plugs or crimp-on?
Can I use my existing screw-on plugs and solder them or do I need to purchase solder-type connectors?
NOTE: I haven't soldered anything in over 20 years. I'd have to buy the equipment from Radio Shack, I guess. Is it simple enough to do?
Thanks.
"God grooves with tubes."
Post edited by Early B. on
    F1nut Posts: 52,142
    edited January 2004
    Hard to beat a soldered connection and yes, it's easy to do.
