Lite audio p100 power regenerator - 100w
doctorcilantro
I have to ship this from overseas. I'd like to get $450 shipped.
LITE AUIDO P100 POWER REGENERATOR - 100W
P100 is a Hi-End power regenerator mainly for audio equipment with power consumption less than 100W.
The special design for this power regenerator is converting the AC input to DC then converting to AC ouput. This design mainly reduce the high frequency noise, reduce the AC side noise that makes a clear background. After using it, the bass will become strong, high frequency noise disappear and more details come out!
Specification:
- AC Input: 220V/50Hz (we can make 110V version, please mention the voltage you need)
- AC Ouput: 110V or 220V selectable and can adjust from 100V to 120V and 200V to 240V (1V per step adjustable)
- Frequency adjustable: 50Hz, 60Hz, 120Hz, 400Hz
- LED display for Voltage/Frequency
- AC output socket: IEC x 2
- Output power: 100W continous, 400W peak
- Over heat protection, unstable voltage cut circuit
- Voltage stable: <0.5%
- THD: <0.03%
- Dimension: 433mm(W) x 322mm(D) x 99mm(H)
- Weight: 10.5kg
Specification:
- THD: <0.03%
- Weight: 10.5kg
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
