Need help with OWM5 Tweeters are blown
stevensound
These are still under warranty and Polk sent me the new tweeters. Need to know how to get into the OWM5 to replace the tweeters I got from Polk. I did not want to damage anything but no screws are visible on the OWM5's. It looks like they may be under the rubber part where the screens pop into the body. I did remove the screens so I got to that point. Any one else know what to do?
Hello stevensound,
Thanks for posting on Polk's forum. If you remove the six rubber "catch cups" with a pair of needle nose pliers you'll find screws underneath. Once these are out the front baffle will separate from the rest of the enclosure.
Let us know if there's a problem.
Regards, Ken -
Ok will do this now. Thank you :-)
