Ive got the glow
scottyboy76
scottyboy76 Posts: 2,905
edited October 2013 in 2 Channel Audio
The carver tfm 25 arrived yesterday,definitely need to wipe it down,amzing how some things can look so much dirtier in a pic, hooked it all up with the new to us c-11, lovin the sound, very different from our old adcom setup.
Even though the pre was advertized, and looks inside as cleaned withblue shower spray before selling, the moving parts def. have a little static, and once a channel cut out for a split second, while adjusting something.
Looking to find exactly which lube would be best to use after using deoxit d5.
Will be going on a pretty long road trip tomorrow with a friend to pick up a sonic frontier sfl 1, im sure a good cleaning and possibly lube would not hurt it either.
If the sfl is as good as advertized, might be replacing the carver soon.
humpty dumpty was pushed
