DCM TF 500 's rebuild
soundfreak1
Picked up a pair and need to find an original VIFA D-19TD-07 8 ohm tweeter. If anyone has one stashed away I would like to hear about it. Thanks! :-)
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
Check Parts Express, also you see replacement Timeframe tweeters on eBay quite a bit. I believe they are 3/4". Actually these are the ones you want mash here:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-500 -
Parts exp has one marked (_05) but cant give me any info on the diff if any??? They just seem to not have any asnwers.and kept trying to switch me to other tweets. I will have to ck out the bay I guess ( Ihate the bay) thanks all but would still find an original.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
The one's on the bay say they are 5+ ohms mine are clearly marked 8 ohms. confused! Does this guy not know what he has? Or is the tf 350 tweets a little diff from the tf500's?Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Soundfreak,Good luck to you, as an owner of TF 350s I have been told that these are one of the hardest PINTA speakers to work on. Being both sock style and then w/ a nasty headliner material behind that.Thankfully mine were resocked and refoamed before I bought them ,I hope your a handy guy and again good luck w/ your project.Sorry can't help technically but I was amazed at the sound coming from such a wacky designed speaker and again mine are even a model below yours.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
These are marked 8 ohm .The seller likely just tested DC resistance (with uncalibrated DMM)which usually measures an ohm or two less than the rated nominal AC impedance,which of course varies with frequency. -
To the OP. I would prob jump on these. I have many vintage DCM speakers but unfortunately not the 350 or the 500. If I did i would pull the tweets to verify they are same or not for you. From past research I would believe them to be the same but am not 100% sure on that. however vintage DCM , like Polk, famously used the same components in various models. I'll keep watching them too. If you don't get them I may pick them up as spares for my 1000's.If con is the opposite of pro, is Congress the opposite of Progress?!
