Straight Wire Encore II IC's
EndersShadow
Anyone have any familiarity with these interconnects? Trying to determine where they land in the scheme of IC's.
Say compared to Signal Cable, Kimber Kable Hero, PBJ, and Audioquest G-Snakes. Would love a comparison to Dougs cables, but doubt that one has been made..
Thoughts appreciated.
Manufacture info below and link here: http://www.straightwire.com/interconnects.html
_____________________________________
Encore II IC utilizes OFHC conductors with the highest grade of Foam Poly-propylene insulation for uncolored presentation with engaging vocals. Straight Wire's most advanced Star-Quad design, Encore II, provides realistic tight bass and true upper frequencies regardless of cable length. This cable's high compatibility with nearly all components makes it a clear choice above the competition. Discover the significant improvement Encore II can make with today's top rated digital receivers and most separate components.
XLR (balanced termination) and Telescopic termination
(tie the shield to ground at one end) are available along
with standard RCA termination
Clear Jacket over Red Braid
Diameter 8m (.31")
ENI info -View/Download PDF
(Opens in a new window)
Diameter 8m (.31")
Post edited by EndersShadow on
I just posted in the power cable sale thread too.
I own a pair of 3m Straight Wire Encore II cables that I use for my Teac X-2000R deck (for playback). They are good cables. I would not say at the same level as MIT Shotgun S3's, but they are good cables. They are similar to mid range Kimber's, IMO. Hope this helps.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Thanks, that was what I was looking to know. I think I will probably pass on his offer. I dont really need IC's as much as I need straight cash right now. That and honestly the color would probably drive me batty..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Yeah, if they are only .5m in length I am not sure it's a great deal for you. Not terrible, but not great. If they were 1m length I would definately say trade for them. If you don't need them, then I would suggest passing too.
Yeah, I dont need em TBH. Anything I would take in trade would be only something I knew I could get sold just as quick.
But we will see if I end up selling this cable. I might hold onto it and sell it in a package with my Carver M1.0t."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Ended up passing on them, and the Tara Labs cable is now sold....
Thanks for the help headrott!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
You bet.
