Anybody use blue shower spray cleaner?
scottyboy76
scottyboy76 Posts: 2,905
edited October 2013 in Electronics
Just bought a carver c11 pre off ebay, says it had been cleaned and checked by a shop, looks very clean, asked what cleaner they used, he said blue shower.
I never heard of it, looked up a lot of good reviews, however their newer g3 spray had one forum discussing it melting plastic in switches and ruining some stuff.
Was thinking of using a little deoxit gold on switches,etc., just didnt want to mix if possibly hazardous.
humpty dumpty was pushed
Post edited by scottyboy76 on
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited September 2013
    Never heard of it Scott. I'd use caution based on the reviews around anything plastic. Personally deoxit works so why take a chance.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    I've used Blue Shower in the past with no problems, many audio repair shops use it. You should be fine.
  • Polkersince85
    Polkersince85 Posts: 2,883
    I'd use Caig's POT cleaner if anything on my C11. You could use the Gold on the RCA's.
  • scottyboy76
    I own a couple cans of caig g5, thought it was good for switches etc.
    Will be looking for the pot cleaner if i do decide to clean the switches, thanks guys
    mhardy6647 Posts: 35,276
    edited October 2013
    Used to use it years and years ago (more accurately, my father used it in his business as a repair-person) - I use CAIG products now because they do seem to work the best of the stuff currently available on the "tough dogs" (to use the old TV service-person patois - or, probably more accurately, argot).
    FWIW, I was sold on the performance of CAIG's DeOxit when it rescued the perennially recalcitrant function selector switch on my McIntosh C-28. None of the other contact cleaners I'd tried (and there were a couple) did the trick.
  • zingo
    zingo Posts: 11,258
    edited October 2013
    Here is the description of Techspray Blue Shower II Degreaser & Cleaner:
    "This blend of HCFC-225 (Asahiklin AK-225) and ethanol was developed for general cleaning and degreasing. Non-flammable and safe on plastics, Blue Shower® II is ideal for precision cleaning of polar and non-polar soils including hand oils, solder oils, greases, silicone, fluxes, and similar soils. Excellent for tape head cleaning and general degreasing. Blue Shower® II can be used in vapor degreasers and batch cleaners, as well as hand and bench-top applications."
  • CoolJazz
    CoolJazz Posts: 572
    edited October 2013
    I found some Blue Shower among my stuff this afternoon. Sprayed some on my hand. Dried and nothing there after about 20 sec or so. Leaves nothing for the pot to work with for a lubricant. Would clean but won't leave a lubricant at all behind. So you would really need to follow with something else.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
