RTiA7 vs TSX550t
Looking to put together a 7.2 setup for a 12X20 room to be used mainly for movies, some gaming and basically no music. I was initially looking at something like this:
2 TSX550t's Fronts
1 TSX250C Center
2 BIC PL-200 Subs
4 F/XiA6 Surrounds
But then was wondering if shouldn't go with something like the RTI A7s for fronts and the CSIA6 for better timbre matching as pricing is about the same. I've read conflicting things about whether it was important for surrounds to match the fronts.
Any thoughts?
2 TSX550t's Fronts
1 TSX250C Center
2 BIC PL-200 Subs
4 F/XiA6 Surrounds
Any thoughts?
Post edited by Zooch on
I've never heard the TSX line to directly compare them, but i'd personally go with the Rtia line for the same price. Not crucial for surrounds to timbre match the fronts but it never hurts, welcome!
I have had the Polk TSX550T for about a month now and they sound really good to me. Very happy with them.
The only difference that I can say that changed with break in is some male voices that sounded, like what I think the reviewers call bloated or tubby, cleared up after about a week. Maybe it was because the voices overlapped the 5 1/25" midrange and 8" woofers and they started to work together better after several days of operation.
I ran them full range with the center, surrounds and sub turned off to give them the full frequency range of the source material for about two weeks for break in. I am now running them full range with with center and surrounds crossover set to 80hz and the sub set to about 50hz to get the lower hz. I know that is not the recommended way but I like it that way. I run them full range because I like the way the bass sounds and my Marantz receiver does not seem to mind the load. I have them biamped as I did the Inifinities.
I replaced some 16 year old Infinity Cappa 7 series II with the Polks. The Infinity's cost more than the TSX550T's but the Polk's sound better to me especially the base and mid range. The Infinity's have 10" woofers and sound a little boomy when run full range. I had them set to small and crossed at 60hz.
I have never heard any really expensive high end speakers to compare them to but I am very happy with these.
I ordered a TSX150C center that will be delivered tomorrow. I hope it is a good good match for the towers. -
..But then was wondering if shouldn't go with something like the RTI A7s for fronts and the CSIA6 for better timbre* matching* as pricing is about the same. I've read conflicting things about whether it was important for surrounds to match the fronts.Samsung 60" UN60ES6100 LED, Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga: LCR mids “Foamed & Plugged**”, inside* & out
*soldered **Rob the Man (Xschop) LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & Mids - 981, connected w/Monoprice Premiere ICs
Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s
