Schematic for parasound hca-1200
laotzu61
anyone know where I can find one online, or whatever? the only one I can find is for a 1200II, and
I wouldn't think they're the same. thanks.
"The symbol is not the reality"
Post edited by laotzu61 on
If you can't google for it on the net, you will likely have to contact parasound to obtain one. They sometimes send the service manual to the owners but they will most likely ask you to send the amp in for repair.
Anyway, what's going on with your amp?Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
took a break from cleaning. the amp is good to go, thank god. the problem is apparently in the pre. just want a schematic for
reference."The symbol is not the reality" -
thank you, Kenneth. I thinl I will try to contact parasound also, just for the hell of it."The symbol is not the reality"
the one Kenneth posted is the same i received from HiFiEngine. just to back things up.Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2
