Polk Lsi-9+ Subwoofer + Emotiva power amp vs Lsi-25 with its own internal amplifier
grigorianvlad
grigorianvlad Posts: 69
edited September 2013 in Speakers
Hi. I have a small home theater setup in my office. For watching news and listening to music while working.
It currently uses the following gear:
Polk Lsi-9 - front left and right
Sunfire HRS-10 - Subwoofer
Pioneer VSX-53 - Receiver, powers surrounds only
Emotiva XPA-3 - Power amplifier for left, right and center
Of course, there are also the center and surround speakers, but they are beside the point here.
I like the Lsi-9s. They are terrific speakers. But now i am beginning to like the Lsi-25s even more. I have never auditioned them, but i am trying to get that arranged. I may get them but only if they will improve quality of the sound even further.
Here is the question. Are Lsi-9's tweeters and midrange drivers identical to Lsi-25's? If they are, then I dont need to upgrade them because Lsi-25's bass driver is not as good as the 1,000W HRS-10 Sunfire subwoofer, plus Polk's amp is limited to only 150W of internal amplification.
If the 25s, on the other hand, have better tweeter and midrange - look identical to Lsi-9's, though - then I need to go with the Lsi-25.
They 3 fronts are powered by an Emotiva XPA-3 power amp which pumps 300W into 4ohm. It really opened the Lsi-9s up.
Thanks a lot for your help
DAC: Mytek Brooklyn DAC+ || Processor: Marantz AV8801 11.2 Ch || Power Amp: Audio Research Reference 75 (75W tube) || Speakers: Magnepan 3.5R / Focal 1037BE || Sub 1: REL 212/SE (1,000W). Sub 2: REL S/3 (400W). Sub 3: Sunfire TS-EQ12 (2,700W). || Cables: Cardas Clear, MIT Matrix & Terminator || Power: PS Audio PowerPlant P5 || Headphones: HifiMan HE560 || Turntable: Pro-Ject RPM5 w SoundSmith Zephyr MKIII || Phono: Gold Note PH-10 + PSU-10 .
Post edited by grigorianvlad on
    EndersShadow Posts: 17,698
    The LSi 9's are the top half of the LSi 15 and LSi 25. Your Sunfire is better than the 25's so I would stay with what you have. If anything look at the LSi 703's as they are better than the 9's.
  • grigorianvlad
    Thank you, EndersShadow.
    That is the info I was looking for.
    Regarding the LSi 703s. How are they better? The specs, the actual sound?
    I have never heard them.
    Thanks again
    Thanks again
    The 703's are a redesign of the 9's and many members like them much better. They are a 8 ohm load, feature a tweeter mid and bass speaker. You can look around the site for info or start another thread, but you will see lots of folks sold their LSi's and went to the LSiM's.
    They have similar spec's but due to the redesign some like them LOTS better than the 9's. Polk took its time and did a good job at the new models and they are an improvement.
    The 703's are the only bookshelf in the line and then it goes to the 705 (LSi 15 replacement) and 707 (LSi 25 replacement)
  • hertz9753
    hertz9753 Posts: 310
    You could also have your crossovers modded.
    AVR-Onkyo TX-NR808
    Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
    Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
    Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
    Sub-Velodyne SPL-1000R
    F1nut Posts: 51,713
    Does your center channel match?
  • grigorianvlad
    That is a good point, actually. No, center channel is a BIC VK-6LCR speaker. I should probably be concentrating on replacing the center, instead of the side speakers. The BIC sounds OK, a very sensitive speaker, frequency response is good, rated at 8ohm (Pioneer Elite receiver calibrates it accordingly). But Polk's LSIM704C or at least LSI-C would probably be much, much better. I have not heard either one, but my experience with the Lsi-9 has been simply an eye opener, especially with the power amp. I assume upgrading the center to a Polk speaker will bring it to life.
    Incidentally, I wouldn't mind getting a third Lsi-9 to be used as a center. What do you guys think about that? Can a bookshelf speaker be used as a center with the same results as dedicated center speakers which were created specifically for dialogue?
    Thanks for pointing the center out, 80% of a movie comes from it, after all. An important factor!
    You could use a LSi 9 as a center, or 2 LSi 9's as a dual center (a forum member here has done this with his setup). At this point any LSi speaker will be harder to find given they are no longer for sale on Polks ebay website, however the LSi 9's are going to be easier to find than the center.
    That said I believe a forum member here as a LSiC in decent condition he is looking to sell. If your interested let me know and I will put you in contact with him.
    ZLTFUL wrote: »
    Guess that's what happens when you get interrupted when posting...Dan comes and makes your post for you. LOL.
    :wink:... I do what I can :biggrin:
    F1nut Posts: 51,713
    Indeed you should.
  • grigorianvlad
    ZLTFUL wrote: »
    TI have 2 but am only using one and am trying to sell my spare but I am not here to pimp my stuff hehe just give some advice from experience.
    No problem, pimp your stuff all you want. Nothing wrong with that. Pimping is an old and honorable profession, has been since time immemorial!
    How do I PM you (or you can PM me)? Lets see if we agree on price. Also, please send her condition - packaging, manual, scratches on her (however small).
    Thanks a lot, ZLTFUL
  • nhhiep
    nhhiep Posts: 877
    if you can integrate the lsi9s well with the sub, then keep what you have now. you're downgrading if you go with the lsi15/25 route.
  • sk88
    sk88 Posts: 159
    This would be my suggestion to you in sequence of improved sound which happens to be in line with cost:
    1. replace LSi9 with LSim 703. LSiM is in a different league than LSi. I have LSi25 and LSiM705 and the difference is very obvious.
    2. replace LSi9 with LSi15 . LSi9 is not as transparent as either LSi 15 or 25.
    3. upgrade XO in LSi9 with VR3. Worth every penny of it.
    Also, upgrade the center as others alerady mentioned if you care more than just listening to 2ch music. I don't suggest LSi25 because you alreay have bass covered.
    • Online - Focal Solo6 BE, Polk PSW10, Focusrite Saffire Pro 24 DSP, Lenovo x220t
    • Music/HT - Lsi25, Lsi9 (Vr3), Lsi7, LsiC, Pioneer SC-68 & BDP-62FD, PS3
  • PSOVLSK
    PSOVLSK Posts: 5,372
    sk88 wrote: »
    I agree with #1, but I'd do 3 before 2. Unless of course he wants to buy my modded 15's:)
