confused
parke 15
parke 15 Posts: 7
edited December 2001 in Technical/Setup
What is the difference between the rt3000psa and the rt55,
aside from $100@
Post edited by parke 15 on
  • Aaron
    Aaron Posts: 1,853
    The RT3000 satellite is a sealed enclosure and has higher power handling. The sealed enclosure should produce cleaner mids and highs at the expense of less bass output (which you shouldn't need if you're buying the subwoofer portion of the RT3000's).
    Aaron
  • jcaut
    jcaut Posts: 1,849
    Also worth mentioning that the RT3000 satellite has a fixed 80Hz high pass crossover.
  • Aaron
    Aaron Posts: 1,853
    Good call!
    Aaron
  • hoosier21
    hoosier21 Posts: 4,415
    Really not trying to pick a fight here, but the higher power rating is most likely a result of the fixed 80hz high pass crossover.
    If the drivers don't have to produce the low fq, it would make me think they can seal up the cabinet and raise the power rating.
    I would like to know if I am right on this, this has come up before that the 3000 sat is made of better drivers and such, does anyone have a pair? are the drivers different that the ones in the RT55's?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • rskarvan
    rskarvan Posts: 2,374
    RT3000 drivers are black. RT55i drivers are blue.
    They are visually different. I believe the RT3000 driver is a little bit more tweaked.
