2M Power Cables
cstmar01
Well changed my set up and needing some decent (not sure expensive but good) PC's. I need 2M for my monos I got. Let me know what you got. Something like Signal cable etc. probably nothing over 300 at this point.
PS Audio, Signal, Wireworld along those lines would be great.
Post edited by cstmar01 on
I have one PS Audio Punch power cable that might be long enough; the other is currently in my system. I can check when I get home if you are interested.
You interested in two of them then or just one? If two, matching ones??Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Two of them and would like same manufacture.
Gotcha.
I think I have two matching 2M Iron-lung Jellyfish PCs, as well two matching 2M HP industrial 12AWG(ish) PCs that I used from my Martin Logan's at the time.
