R30's
Tonight I got a CSI40 and I have some R 30's what I want to know is this, can I upgrade the parts in the R 30's. The reason is I have just enough space for thier size. I would like to match them to the CSI40 with out getting a bigger speaker for space and height.
Post edited by Hitler on
nope
If you want more help you might consider changing you screen nameGraham
Why?
hitler? c'mon, if you dont understand how that might be offensive to people then you are beyond help.
What's up? I came on here to ask a question not get into some **** over my name.
i gave u an answer, u cant do it. unless you want to change the crossover and most likely modify the cabnit too. its not worth it. you can get an r series center, live with the unmatched front, or get rti series mains.
if size is an issue then consider bookshelves. rti28, and rti38's will match your center, and will still sound better then r series speakers. -
Thanks, is the R 30's timber matched to the csi40?
no, they use different tweeters. if you can really tell a difference then you will need to get different speakers, either a different center of different mains. i would suggest different mains. if you really can't tell a difference then dont worry about it. theres people that use different speaker brands together and different series together. what sounds good to you is best.
to each his own, im not interested in his philosphies. this is a speaker forum, and thats what we are talkin about.
I see, you see a name like HITLER and you play the race card right away your a moron. Let me tell you something I'm a Outlaw Biker from Chicago I happen to be german so for more then 20 years people call me Hitler nothin to do with race **** but I don't like jag offs who start **** with out knowing someone.
sorry for the misunderstanding
