Power Hungry SDA 2B's ???
Summerwind2
Summerwind2 Posts: 98
edited September 2013 in Vintage Speakers
So I connected my SDAs to my Pioneer Elite VSX 05 switched to 6ohm.
Its a solid 100wpc into 8ohms but man I had to crank it up to 50% volume for the SDAs to wake-up but still was lacking mid bass.
I've placed them 10' apart and 6" from the wall and I found the sweet spot dead center @ 8 to 9' from the SDAs.
I'm thinking I need more power to get that mid bass punch.
Thoughts?
Post edited by Summerwind2 on
  • Nightfall
    Nightfall Posts: 10,086
    I believe they're like the RTA-12's in that they can take 500 watts? Everyone recommends a lot of power to get them to wake up.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Mystery
    Mystery Posts: 2,546
    I have studio 2B's and if I go near 1/2 on my Pioneer Elite VSX-07TX Receiver, I have to put palms over my ears.
    May be your input level is too low or the room is huge.
  • Nightfall
    Mystery wrote: »
    I thought I remember a Marantz?
    afterburnt wrote: »
  • bigaltx24
    bigaltx24 Posts: 141
    Make sure they're not hooked up out of phase. If they are in phase you might want to consider a higher power amp.
    Denon PMA-900V
    Linn Axis with Grado Red
    Cambridge Azur 650C
    Polk SDA-1BTL
  • polrbehr
    polrbehr Posts: 2,834
    I think something is amiss here. I run my 2Bs with an Adcom GFA535 @ 60wpc, and at -10 you can feel every note.
    It almost sounds like the SDA cable isn't hooked up (I know that's not likely, but it's worth checking IMO)
  • TennMan
    TennMan Posts: 1,266
    I have an Adcom gfa-555 (200wpc) but the Adcom gfa-545 (100wpc) use to have powered my 2Bs without problems. When comparing them I never had to set the volume higher for the lower powered amp. With either amp the sound was/is best with the volume set on my preamp at about 35-40%. 50% will run you out of the room (14'x20'). With 100 watts you should have plenty of power unless you still have a disco ball hanging from your ceiling. lol I would check all the connections to be sure the polarity is correct. Having the polarity wrong can have a big effect on the bass and the SDA effect of the 2Bs.
  • Summerwind2
    It's a large room. 16' wide and 24' long with a vaulted ceiling on thick rugs
    I'm sure it's in phase but will check again and report back.
    It's loud, clean, great staging but it's lacking depth.
    And the ball stays :cool:
  • Nightfall
    MCACC didn't do anything weird did it? Like set a real high crossover point?
    afterburnt wrote: »
  • Summerwind2
    Nightfall wrote: »
    ll
    All settings are flat. I can play with the crossover via GUI.
    gudnoyez Posts: 8,132
    I also have run my 2B's off my Adcom gfa-545II and my gfa-555II and agree both do I fine job, at 50% on either one would run you out of the room and piss the neighbors off, all while sounding fantastic.
  • zingo
    zingo Posts: 11,258
    I know with the 400wpc that I feed my SDAs, they sound fine but flat with the volume at 9 o'clock. Once I get passed there, the sound stage gets much deeper and full, the music is more dynamic and punchy, and overall has more weight.
  • Nightfall
    Is it appropriate to compare a dedicated amp to an AVR? I'm in no way saying you guys are wrong, don't take it the wrong way. I've heard nothing but good things about Pioneers D Class AVR's and it's on my list to replace my Yamaha but I'm still curious if it's a fair comparison, as good as they are.
    afterburnt wrote: »
  • Summerwind2
    Nightfall wrote: »
    I think its fair in 2 channel mode with no effects. (DSP) AVR is only powering the SDA
  • Nightfall
    Also, don't quote me, but I remember reading something saying the ICE amps don't handle low impedance as well as the newer SC's.
    afterburnt wrote: »
  • zingo
    zingo Posts: 11,258
    ICEpower amps are usually pretty good at low impedance/heavy loads, which is why they are often used for subwoofer duty.
    F1nut Posts: 50,748
    Switch back to 8 ohms as all you're doing with the 6 ohm setting is limiting current.
    Thick carpet means you must spike the speakers otherwise you'll never get any kind of bass punch.
    Are they on the short or long wall? How far from the side walls? 10 feet apart is pretty far, try 6 to 8 feet.
  • Nightfall
    I'm not sharing this as fact, just passing it along. Could be BS?
    This receiver uses class D ICE (Intelligent Compact Efficient) amps.
    This highly efficient, almost 100%, topology of class D amps was developed by Karsten Nielsen for his PhD thesis he defended in 1999. This technology has been developed by B & O who bought out Nielsen's share in July of this year.
    B & O have licensed this technology to among others, Samsung for mobile phones and Sanyo for the development of dual channel output MOSFET switching amp chips, which appeared in 2004.
    B & O have produced high end amps for among others ROTEL and Jeff Rowland.
    The Sanyo chip has been embraced by the car audio amp manufacturers. Obviously amp efficiency is a big concern to them.
    Now one of the problems with class D amps has been a very narrow optimal impedance range over which they work optimally. So the use of this technology has been very attractive for speakers with active crossovers and the amp connected to the drive units directly. In this way the impedance is a known quantity. Car audio manufacturers and enthusiasts have for a long time embraced active crossovers and bi and triamping.
    Now we have long suspected that the next wave of A/V receivers would embrace this technology and the Sanyo chips in particular. These produce virtually no heat, are very cheap, small and minimize power requirements and ancillary circuit components.
    I think I would be correct to assume that this Pioneer receiver uses the Sanyo dual MOSFET chips.
    Now this post has caused me to study the details of these dual channel chips.
    The following chips are available, 100 watts X 2, 150 watts X 2 and 200 watts X2
    I assume that this receiver uses the 150 watt per channel chips.
    Now these chips are 4 ohm rated, however there is a snag.
    The line voltage of these chips is 33 volts. This gives 150 watts per channel into 8 ohms. The power into 6 ohms is 180 watts, and the power into four ohms is 150 watts, but THD rises to a whopping 10%
    Now the THD into 8 ohms at 130 watts is an excellent 0.05%. At 140 watts it is 0.09%
    At 180 watts into 6 ohms, the THD is 1%
    Pioneer do not state THD figures below 6 ohms. However the Sanyo spec sheet quotes 10% THD at full power, 150 watts into four ohms. I can not find a power curve, but I suspect that at lower powers distortion drops.
    http://forums.audioholics.com/forums/amps-pre-pros-receivers/47503-pioneer-sc-07-4-ohm-speakers.html
    afterburnt wrote: »
  • deronb1
    deronb1 Posts: 5,021
    Check for air leaks. A properly sealed cabinet will not have to be cranked to achieve good midbass depth on 2Bs. They are efficient 90db.
  • Summerwind2
    I too was thinking about switching back to 8ohms and carpet spikes
    They're on the short wall and 3' off the side walls.
  • Summerwind2
    Nightfall wrote: »
    Nightfall, great short meaningful read, thanks for doing the leg-work.
  • Easy Runnin
    Easy Runnin Posts: 501
    If your interested, I could stop by tonight with my NAD 2400.
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
  • Summerwind2
    Hey thanks for the offer. I may take you up on this. I'm going to connect my Advent 1's to use as a control variable. I want to ensure all SDA connections are proper and the speaker are sealed.
  • Summerwind2
  • smglbrth
    smglbrth Posts: 1,481
    This^^^ When I had my 2A's a little over 8ft apart it sounded a little "hollow". When I put them back to 7ft apart the warmth and fullness came back. For me, it didn't matter how many feet they were from the side walls (over 3ft that is, they are more than 7ft now). For reference mine are also about a foot away from the back wall...
  • Mystery
    Marantz is for H/T (Deftech BP10, B&W 110i, MA 301) and the Pioneer is for music (2B, CRS+ and Boston A400). :cool:
    When I play movies in blu-ray, the output level is so low that I have to increase volume by like 4 times more than from my computer.
    DVD players are not that bad.
    For example, my normal level is around 33 on the Marantz playing via computer.
    DVD is around 25 and blu-ray I have to increase it to 15.
    Less number volume is higher in this receiver.
    If I play song at 15 from laptop, it'll bleed my ears.
  • Summerwind2
    Question; Do input sources have any impact on sound quality? CD vs Tape vs DVD?
  • zingo
    zingo Posts: 11,258
    Nightfall wrote: »
    Why not? He's asking about performance and if that correlates to power. As posted by a few other, there may be issues of spiking, placement, cabinet seal, but if someone has a more powerful amplifier and doesn't have mid-bass issues, wouldn't if be helpful for him to know that?
    Nightfall wrote: »
    Not BS, and thanks for the read, but the specific implementation of ICEpower modules in Pioneer gear is very different than in other designs. I know that Wyred4Sound does not have any problems with low-impedance loads on their amps, but they have purpose built a customized the ICEpower modules with a matching power supply. Even an ICEpower amp that I built for my father-in-law with a stock pair of ASP modules to power his LSi15s have never had a problem or run out of steam. I like the Pioneer class-D receivers, but like any receiver, they have to make design sacrifices.
  • Polkie2009
    Polkie2009 Posts: 3,834
    I know on my Yamaha 663, I can adjust each input sources db's + and -, are you having the same problem when you listen to a cd or tuner, mp3, or other dvd player etc.? +1 on Easy Runnin's offer to try the NAD , see how she runs with it.
  • BlueFox
    BlueFox Posts: 15,251
    Of course they do. Nothing personal, but if you are asking that then you have a lot of learning to do. As others say, "Get your read on", and start researching.
    And, cables (power, speaker, interconnects) also have a huge impact on sound quality, so it isn't only the source that matters.
  • Summerwind2
    BlueFox wrote: »
    Blue Fox, I would like to think we all have much to learn, so maybe you can help by shedding some light on this issue for me if you don't mind.
    What would one significant difference if I used a CD input source over a tape input source? Thanks!
