Center for Rti12's
thekidd747
thekidd747 Posts: 3
edited September 2013 in Speakers
I've been reading the threads, mostly old about what center speaker to match to Rti12's
I got the towers on boxing day for $350 for the pair after a bunch of bitching and moaning
so not really in the market for a $400 center. Also not sure I have room for an Csia6.
I had thought originally I would wait for a deal on a Csia4, smaller and the drivers are the same size as the top ones in my towers.
I am finally going to figure this out and get one, should I still be sticking with an Csia6, Csi5, or Csia4.
The newer Tsx150 TsiCS10 are out of the question right? Some have good reviews but won't match as well right?
Also any leads on where to find a cheap one
Post edited by thekidd747 on
  • Irrenhaus
    Irrenhaus Posts: 1,092
    Welcome
    I have the CSi5 with My RTi12's and is all good. Now dont know were are you located and if you can find one by now but Frys has the CSi5 for $99.00 and that's is a deal.
    Cheers
    http://www.frys.com/ads/page17
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • B Run
    B Run Posts: 1,888
    I also run the Csi5 and I think that's your best bet. It'll sound better than the Csi3/a4 and match better than the Csia6 if you're concerned with them matching.
  • thekidd747
    thekidd747 Posts: 3
    I am in Canada, I see most Fry's with them in stock are in California
    Seeing if the one girl I know there can drive into San Diego and hook me up.
    Guess a couple Rti'6's would complete the whole package for another $99
  • thekidd747
    thekidd747 Posts: 3
    I have some on hold in Oxnard California but my friend can't get there before the store closes, anyone else wants them ill send you
    The quote number
