To preamp or not
Steven72555
Steven72555 Posts: 35
edited September 2013 in 2 Channel Audio
I have Pioneer SA-7500 amp which I want to hook up a cd player.
It doesn't have a cd input, it has an aux input I am using for an MP3 player.
I currently plugged the cd player into the tuner input, it sounds okay. BUT, will this hurt the amp?
OR, should I get a modern preamp with all the inputs that I need?
Post edited by Steven72555 on
    mhardy6647 Posts: 33,964
    Any "line level" input is fine - that includes tuner, aux, and the two(?) tape monitor inputs ("Tape Playback").
  • newbie308
    newbie308 Posts: 772
    According to the schematic diagram, the Aux input and the Tuner input are wired to the same point via the selector switch, so I don't see any issue with what you are doing. In essence, the only difference is the label.
    Sources: Technics SL1200MKII | SME3009 Tonearm | Monster Alpha 1 MC cartridge | Oppo UDP203 disk player | Nikko NT-790 analog tuner | Musical Fidelity Trivista 21 DAC | Preamp: Threshold SL-10 | Amplifier: Threshold Stasis 2 | Speakers: Snell Acoustics C/V | Kimber 12-TC bi wire speakers | Analysis plus Oval 1 preamp to amp | Wireworld Eclipse 7 DAC to Preamp | Wireworld eclipse digital IC Oppo to DAC | Audioquest Quartz tuner to preamp |
  • leftwinger57
    leftwinger57 Posts: 2,917
    That's pretty much what I do .Going from my Yamaha rx-v665 avr audio outs into my Onkyo P301 pre/amp into the tuner section inputs.This way I get I-net radio , my dock w/ i-pod, and F.M. and t.v.Cdp and tt/ phono inputs go direct. This affords me a healthy dose of flexabiliy and variety into my 2-chll rig.
  • Steven72555
    newbie308 wrote: »
    All right.. Thanks for the input.
  • ZLTFUL
    ZLTFUL Posts: 5,655
    HA!!! I see what you did there! :lol:
    ZLTFUL wrote: »
    heh. Input. I get it!
