SRS side panels
tygr1955
tygr1955 Posts: 45
edited September 2013 in Vintage Speakers
Can I use Loctite Power Grab to reglue the side panels on my 2.3s? Should I use something else?
Post edited by tygr1955 on
    F1nut Posts: 50,748
    Yes.
  • heartystatue
    heartystatue Posts: 329
    I used it to reglue the inside edges all the way around with the speakers removed. Are you talking about reattaching one of the whole sides?
    HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
    2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC.
  • tygr1955
    tygr1955 Posts: 45
    No just a couple of loose ends.
