Matching center channel for RTiA1
bludhemn
bludhemn Posts: 1
edited March 2014 in Speakers
Hello
I've purchased two pairs of RTiA1s from the Polk store and am looking to complete the setup with a matching center channel. I read in the forum that the CSiA4 are a good match for this. I was actually considering the CSi5, which was on a good deal on ebay, but am not sure if they mix well with A1s.
Can you please share your thoughts as to which all options I have? My budget is rather limited (around 350$) and I dont mind second-hand.
Thank you
Post edited by bludhemn on
    gudnoyez Posts: 8,156
    edited September 2013
    The Csi5 would be a good match if you don't have the funds for a Csia6 the Csia4 is perfect for your Rtia1s. Welcome to the club.
  • jbooker82
    jbooker82 Posts: 1,627
    I run the CSI A4 with my RTi A7's and don't have a problem. The CSI A6 is huge and I do not have any room for it.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • bettegamsp
    bettegamsp Posts: 2
    edited March 2014
    I´m wanting to use the RtiA1 with the TL3 or TL2 front speaker because os the size of the others front speakers. I know that i´m loosing quality, but do you think it´s going to be so bad that is not worth doing it??? And, which them do you think would match better with the RTiA1??
