MediaMonkey
hochpt21
hochpt21 Posts: 5,423
edited November 2013 in Going Digital
I have done some research and looked at the various threads here at CP. I have the free version of MM right now and just started ripping some cd's to FLAC.
First question. I am currently ripping with the following settings...
Compression Level - 0
Rip Type - Secure read (takes extra time)
I have not dug any deeper.
Am I getting the best audio quality?
Is it this simple or do I need to dig deeper and put more work in?
Thanks,
Paul
Post edited by hochpt21 on
  • hochpt21
    edited September 2013
    Bumpski
    heiney9 Posts: 25,530
    Compression level has to do with how large the final file is, nothing at all to do with sound quality. I always pick level 8 as it makes the smallest files, but does take a few minutes longer to rip. Secure mode is what you want for best ripping.
    I would raise the compression level or you can leave it as is.
  • snake1
    snake1 Posts: 567
    That is exactly how I do my own, using mm and the compression all the way up. I also load them on a spare hard drive thats connected to my receiver, it works very well
    AVR - Onkyo NR809
    500gb HD for MP3 and FLAC files
    Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
    Mains - Polk RTi12 towers
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    Movies and games - PS3
    TV - Toshiba 52" HD
    Every vehicle has one good nuetral drop in it
  • Thorton
    Thorton Posts: 1,324
    I've left it compression level 6 in secure mode. So far I can't complain.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • hochpt21
    Thanks folks. I always think of compression as a negative buzzword which is why I turned it all the way down. But what you're saying makes sense.
    I'm also looking to put them on a spare hard drive as a backup in case something happens to the laptop. What size spare hard drive do you use snake1?
  • snake1
    snake1 Posts: 567
    500gb right now, I just started this myself not long ago so that may seem small to some. The HD will need to be formatted to use with an avr. If you need some help with it just let me know.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • steveinaz
    steveinaz Posts: 19,546
    How do you get MediaMonkey to save your rips in the directory structure/format you choose? Mine keeps defaulting back to a generic setup. For example, My music HDD looks like this:
    D:\Music
    \Artist - Album\Track# - Filename
    so it appears: D:\Music\Journey - Infinity\01 - Lights.flac
    When I try to create this structure, MM doesn't save it
  • ThirdWorldGuy
    ThirdWorldGuy Posts: 39
    Does the HDD go in one of those HDD to USB cases? And then to the AVR via USB?
  • steveinaz
    The HDD is an external/powered WD connected to my laptop via USB.
  • ThirdWorldGuy
    I was thinking of getting one of those Western Digital My Book Live personal cloud devices. Does anyone have any experience streaming high resolution music out of one of those? I guess it's similar to a NAS?
